Question about Gateway GT5674 Desktop PC
No power, can't tell if it's motherboard or power supplyl
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 01, 2009
  • 63 Answers
Best option at this point is to contact your computer manufacturer first. If you prefer to replace the parts yourself, I suggest that you replace the power supply first since that is generally cheaper.
My windows xp computer will no longer power on. I have tried 2 power supplys. Is my motherboard dead and is there a way to tell?
Check the power supply to see if it has power coming from it. if so, then it is likely the motherboard.
Mar 17, 2013 | HP Pavilion Media Center M1070n...
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
How to wire the power cables to the motherboard
The motherboard manual will tell you where all the power connectors go, if you dont have it get it online.
Jan 29, 2012 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Nov 12, 2010 | Computers & Internet
CAN YOU TEll ME WHERE I HAVE CONNECT BUTTON POWER
look for the pins indicating power on the board.
Jan 28, 2010 | EliteGroup P4M800-M7 Motherboard
I have a Viewsonic VE175b that is having back-light problems. Sometimes it takes up to 30 minutes for the backlight to turn on. Sometimes playing with the On/Off switch fixes the problem. To me it sounds...
yes power supply failing. you need to open it and look for leaking capacitors or crwoned ones. desolder the bad ones and take to a parts shop to get new ones and replace.
Dec 24, 2009 | ViewSonic VE175b 17" LCD Monitor
I have spilt coffee over my Sony Vaio PCG-FX501 and now it will not boot. I would like to try to repair it but don't know where to start. Can anyone help please?
if you've spilled sugary liquids over electronic devices, the most common problem is power supply. The power is not getting through to your laptop. Try taking out all the power supplyl; ac power cord, battery, and any other external devices (ipods, usb cables, etc.) Next, dry out your laptop. The most effective way, for me at least, is to open your laptop so that the keyboard and screen is perpendicular to each other Then, turn it upside down and let it hang over the desk. This way the keyboard part is resting upside down, while the flat surface is resting on your desk while the screen hangs over the edge
Jun 15, 2009 | Sony Computers & Internet
How to put all the wiring from box onto the motherboard
can you tell me whitch kind of model from msi you have?
so i can tell you a link to take his manual and wired up your wires.
Apr 08, 2009 | Intel Motherboard
P4VMM2 motherboard
You can download the manual from here (Europe) or here (US).
Sep 17, 2008 | EliteGroup P4VMM2 Motherboard
About motherboard intel 845 GL/GE
Try another power supply. The motherboard LED is telling you the board is in standby mode. Once you power up & LED goes out it's telling you there is a possible power supply problem.
Mike
Jul 14, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Gateway GT5674 Desktop PC Logo
113 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
