Question about Epson Stylus DX4850 All-In-One InkJet Printer
Printing Fault Every time I'm printing a page it on goes in a little with the rollers but then the piece of paper is not picked up and the paper does not go through as the ink is projected The paper is in correctly and there are no items stuck within the printer so I'm completely stuck Please help...
    Novelist:
  • 208 Answers
Remove the paper and look inside, you will see some rolelrs that pick up the paper.
Take a cloth with some soapy cleaner, like fantastic or something alont that line.
Dampen that cloth with them and clean the rollers. May have to clean them 3 or 4 times to get all the comtaminants off of the rollers.
If they still are misfeeding. run your fingertips across them and see if they have a "slick smoothe" feel to them, if so, the are wonr out and in need of replacing.
Posted on Dec 20, 2007
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
My HP Deskjet 1220C printer picks up several pieces of paper when only printing 1 page. Picking up multiple pages when ony printing 1 page.
THE SPERATION PAD IS DIRTY OR WORN.TRY CLEANING THE SEP PAD WITH NAIL POLISH REMOVER.THE SEP PAD IS LOCATED UNDER THE ROLLER THAT PICKS UP THE PAPER
Feb 28, 2010 | HP DeskJet 1220c InkJet Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
Feeder won't work~~
Hello Sir; I believe just replace paper pick up roller feed roller and stop roller, the problem will be gone!
Jan 27, 2009 | Sharp AL-1551CS Copier
Canon Imagerunner C3200 - printing problems
check the feeder rollers and make sure they are grabbing the page at the right time. Sometimes rollers cna get slick and spin for a moment before picking up the paper. This can cause the timing to be off when the page is fed through.
Mar 06, 2008 | Computers & Internet
Printing stops half-way
I had exactly the same problem - seemed to fail to pick up the sheet. I tried reversing the rubber pickup, but although I think this would work in some cases, it didn't work for me. What DID work was SO simple:
Take a piece of paper and fold it in half a few times, then tape it to the bottom of the paper tray, so that when in place, it will be under the pickup roller at the back. Now load with paper. The paper will be slightly raised at the back (below the pick up roller) and the increased pressure will magically make it work like new! Don't obstruct the paper-out detection slot - otherwise it won't know when it is out of paper.
Aug 16, 2007 | Samsung CLP 300 Laser Printer
Epson Stylus DX4850 All-In-One InkJet Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
