Question about LG Washing Machines
How do you remove the rubber seal in a front load
How do you remove and replace the rubber seal in a front load lg washer
    Problem Solver:
  • 7 Answers
There is a spring band on thr fromt lip of the seal and the seal closest to the tub.To remive use a flat slim tool to lightly pry up on the band and it till pop off.Same with the inner band.
Posted on Oct 01, 2009
LG WM1815CS Washer An item was recently washed in my washer with sharp edges. Part of that item broke off and I can't find it. Also, the rubber seal on the frame of the door is now slashed (underneath the...
Have you checked the filter to see if the item has been trapped there? Is so you can remove it and then replace the rubber seal as you describe - not too difficult. I would recommend not using the machine with a broken seal as the machine will probably leak.
Jan 04, 2011 | LG WM1815CS Front Load Washer
Need to remove the rubber seal from my lg front load wahser
why replace seal just clean it much easier there are some really good cleaners on the market but if you realy want to replace remove wire band around seal you will see this around the outer diameter with a tension spring attached pry of carefully lift the top and do the same at other end make sure to turn of power take very good note so you will know how to put back together
Nov 12, 2009 | Washing Machines
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
Circular grey rubber part ..
firstly u have to take the wire off it with a screwdriver unscrew it take it off then watch how the old on pulls off as there is a lip all around this rubber and it as to bed into the metal drum just see how the old one comes off once you have put the new one on put the wire back around it or it could be a metal strat wich tightens up with a screwdriver,rgds,paul
Jul 07, 2009 | LG WM-1832C Front Load Washer
Replace wire clamp around seal
You need a grip clip plier to handle this clip, enquire at a hardware tool shop, with problem. The clamp is tough, you dont want leaks.
Mar 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
163 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
