Question about Gateway Media Center 610XL (610XLMDIA) PC Desktop
My monitor flashes on and off also.
The problem seems to be heat related and directing a small fan at the back of the machine has worked as a fix so far.
  • 380 Answers
The issue definitely sounds thermal. You may want to take it to a shop to get a cleaning, or you may try using compressed air to blow the dust out of it yourself. If the machines has been locking down, then you are overheating your cpu. But, the issue may not be the system. You COULD have a defective LCD backlight or inverter. Your best option is to get it tested in a pc shop or call gateway for assistance.
Posted on Oct 01, 2009
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
Truck overheated never lost any fluid? Never came across this before , usually when motor red lines, you lose fluid.
problem can be directly related to viscous fan hub or fan clutch or horton fan unit
the problem is that during driving there is air flow through the radiator but at idle there is little and with a hot engine it doesn't take much to over heat if the fan is not sucking air through the radiator
shutting down an engine will raise the temp as there is still heat in the block and heads and the water is not being circulated and when you restart it that circulation is not being cooled so the added heat will cause it to boil
Jul 06, 2016 | Cars & Trucks
Unit is shutting down after ten min
My unit never got to the point of actually shutting down due to overheating, but your problem may be related to what I experienced: A bent lamp heat shield.
My Optoma EP739 started exhibiting color-banding and strong color shift after years of great service. After trying other suggestions that didn't work, here is the FIX for my unit. I have not seen this posted anywhere else.
Problem: After 10-20 minutes of use, color-banding and then a strong shift to purple/green with almost no red. If the unit is turned off for 5-10 minutes to cool and then powered-up again the problem goes away, only to come back in another 10-20 minutes. Enabling the "High Altitude" setting in the Setup Menu helped for a while (a week or two) since it forces the main cooling fan run at high speed always, but then the problem re-appeared.
Reason: Overheating. The electronics are overheating. Like several people have suggested: First step: Open the unit up and blow-out/vacuum all of the accumulated dust. Assure BOTH fans (there is a small drum blower directly cooling the lamp and a larger regular fan that circulates air through the entire unit) are operating and clear of debris.
Once you have done that, then look for the REAL issue. With the front panel (i.e.the panel with the hole for the lens) removed and looking into the projector from the front examine the metal heat shield on the right side above the lamp. In my unit, because of years of service and heat, the aluminum lamp housing had deformed slightly, tilting this sheet metal heat shield directly INTO the air stream from the fan. This restricts the airflow enough to reduce cooling capacity. This metal shield should be high enough above the lamp to be TOUCHING the plastic case. If it is bent down and is halfway into the air stream then it restricting the exhaust airflow, causing the overheating.
Fix: Bend the heat shield back up so that it is not in the exhaust airflow. It must be ABOVE the airflow, protecting the plastic case from the heat of the lamp. This simple remedy fixed the issue for me. My projector has been running 2-3 hours a day for 10 days now with no banding issues at all. That's it. Simple fix.
Feb 01, 2013 | Optoma EP739 Multimedia Projector
Anyone who calls me hears their own echo on my pantech burst phone. Any suggestions?
ive had the same problem with my pantech burst, but ive found a solution that has worked so far. look on the back of your phone, next to the camera fash there should be a small pin hole, this is a microphone (not sure why its there). take the back cover off and cover this microphone with a small piece of paper, i used two pieces. i assume the problem is the microphone picks up the sound of the caller and plays it back to the caller. its a crude fix, but its simple and works for me so far
hope this helps!
Apr 04, 2012 | AT&T Cell Phones
My car seems to keep over heating. I just recentl...
I had a similar problem with my 02 grand am, which i still own and i changed the thermostat and it seems to have fixed the problem so far. Keep your heat on high while driving and make sure ther'es enough coolant. The thermostat is relatively easy to change and only cost 10 dollars new.
May 21, 2010 | 2002 Pontiac Grand Am
My 01' Jetta over heats while driving...1 fan doesn't turn on.
Check that the other fan will run if power applied directly to it.
From wiring diagram, it shows both fans are wired in parrallel- thus should run together.
Sep 21, 2009 | 2001 Volkswagen Jetta TDI
My Far Cry 2 keeps crashing back to the desktop, is there a fix for this?
That sounds like a video driver issue. Make sure your direct x and video drivers are up to date. If they are, try a previous version of that driver. also, check far cry website for known driver issues.
Jul 21, 2009 | Computers & Internet
Heat works poorly on fan 1 and 2 and no heat 3,4,5 fan speed
my truck did the same thing. i unhooked the two heater core hoses, and then back flushed the heater core with a garden hose. seems to work pretty good so far
Nov 02, 2008 | 2000 Chevrolet Silverado 1500
X1a powers on, then video dies
Check whether the menu comes on the Screen. then check the DMD circuit.
Jun 04, 2007 | InFocus X1A Multimedia Projector
Gateway Media Center 610XL (610XLMDIA) PC Desktop Logo
225 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
