Question about Husqvarna 28cc Gas Line Trimmer
How to change string on a 128DLX trimmer - Husqvarna 28cc Gas Line Trimmer
How to change string on string trimmer
Need to know what make and model trimmer you have.
Sep 12, 2014 | Garden
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
How to change string on weedeater trimmer electric
Check out the link that I am providing and see if the video helps you out. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
Aug 30, 2009 | Garden
How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Husqvarna 28cc Gas Line Trimmer Logo
218 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
