Question about Kenmore Washing Machines
Keeps filling even after spin cycle - Kenmore Washing Machines
  • 3,600 Answers
You may have dirt in the filling valve that does not allow it to close, try takeing the valve apart and clen it if it still does not work try replaceing the water inlet valve. If you need a place to buy parts post here and I will give you a web site to order the parts from.
Posted on Oct 01, 2009
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
