Question about HP LaserJet P3005n Printer
How to replace fuser drive assembly on HP laserjet P3005. When the machine cycles, it makes grinding noise.
  • 81 Answers
Http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
Posted on Jan 01, 2010
    New Friend:
My HP laserject P3005 printer is blinking attention red light continue how i can print document. Its very much problems with me
Posted on Jun 14, 2013
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Grinding noise
"Swing plate assembly" (RM1-0043-020CN) need to replace to avoid grinding noise. ..Note: Only professionals can perform this activity..
Jan 23, 2013 | HP LaserJet M4345 MultiFunction Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
Paper jam in HP printer p3005n printer in between paper sensor+fuser assembly & toner
These printers have a problem with the bushings on the fuser, as they wear the gear drive moves away and you nolonger have drive to the fuser. HP has a kit, you replace the fuser and the gear driving it. At the same time, you should also replace the feed roller, both are simple to do with a phillips screw driver.
http://www.precisionroller.com/fuser-assemblies---units-for-hp-laserjet-p3005/products.html
for your parts.
Jan 16, 2011 | HP LaserJet P3005n Printer
Every time we print or turn printer on it makes a very loud grinding noise. what are the possible causes
This is a common problem.
You need to replace the "fuser assembly" and make sure when you order it, that it comes with the extra gear. The instructions are simple. You will replace the fuser and the small gear located on the left side as you look in from the back.
If you are in the USA, or Canada, www.partsnow.com is a good place to buy this kit, and they warrantee the fuser for 6 months. The OEM HP Fuser is warranted for 30 days, and may not come with the gear.
RM1-3740-040, Fuser (Fixing) ***'y, 110V, HP LaserJet P3005 Series.
Jan 07, 2011 | HP LaserJet P3005n Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
When printing making loud noise
fuser gears. replace the fuser. part number rm1-3740-030cn
Nov 16, 2009 | HP LaserJet P3005n Printer
Noise form hp laserjet 3005
The gears that drive the fuser assembly are worn out, after replacement grease heavily
I think the part #s are RL1-0077, 78 & 79
Jun 11, 2009 | HP LaserJet P3005 Printer
HP P3005 making grinding noises
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Apr 01, 2009 | HP Hewlett Packard LaserJet P3005 Printer
Grinding noise
This is caused by the swing arm (the part that drives the fuser) HP have modifed this, if you contact them, they may replace it free of charge. A short term solution is to wedge a piece of card or folded paper under the fuser assembly.
Aug 11, 2008 | HP LaserJet 4250tn Printer
HP LaserJet P3005n Printer Logo
4,925 people viewed this question
Seeker5211
Seeker5211
