Question about Bushnell Velocity Speed Gun
The gun has new batteries, but when the trigger is pulled I get nothing except the mph with no digit..should i be holding the trigger down as the ball passes the gun?
    Problem Solver:
  • 10 Answers
I have two of these radar guns and they both work well, you have to be at either behind the ***** or behind the catcher. Hold the gun and point directly at the target, pull the trigger and hold the gun still, after the ball is pitched and caught release the trigger. Remember this is an inexpensive gun, so it won't work if you are pointing it at the ball as it goes past you, you must be infront or behind the pitcher, but it is very accraute and well worth the money.
Posted on Oct 25, 2009
  • 85 Answers
Yes you need to hold the trigger down as it passes by
Posted on Oct 03, 2009
Why does it fire two nails constantly?
what do you mean fires two at one time or two like bam bam.? different things all together. two at one time is the nose piece and normally occurs on coil nailers when they wear out. If its bam bam then, yout trigger is black and its called a contact tip trigger, meaning as long as the safety is pressed down and the trigger is held it will fire. But common problem is when people use a gun and put it on the board and pull the trigger. Like any gun there is a " kick" the kick is the operation of air going through the gun hitting the piston which is attached to the driver, pushing the nail into the board, ( a lot of energy directed straight down) pushing the gun up. and the trigger while released actually is making you pull it twice. So, as a tech I teach new people that there is a sequential trigger that does not do that or if your good with your aim try holding the trigger and tapping the board a single time.
but long and short of it, nose worn ( pricey) or trigger
Aug 18, 2015 | Air Tools & Compressors
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
NEW BRAD NAILER ONCE LOADED WILL NOT WORK
Many modern brad and finish nails use a sequential fire trigger system. You have to push the nose of the tool down to depress the safety THEN pull the trigger. This is the opposite of how a bottom fire works where you hold the trigger and bump the nose to fire the gun.
Mar 02, 2012 | Air Tools & Compressors
I have a new Surebonder rechargeable glue gun. I was gluing a large pc. and rushed to get another stick and it would not feed by pulling the trigger, There was one glue stick (partial) still in gun, but...
it sound like the charge ran down, recharable glue guns are not typically recomended for large project becuase heating elements run down batteries very quickly. to get the stick out of your gun, you will need to fully charge it and then after that turn it on and when its warm pull the trigger and the glue should once again come out, For large project I would recommend you purchase a wired (plug in the wall) type glue gun. Thanks for you question
Mar 22, 2011 | Crafts & Hobbies
I installed a new grease cartridge in my grease gun and grease does not come out when triggered.
If the gun was working properly before you changed the cartridge, The gun is air-locked
Two things: 1. Make sure the bottom rod is pushed in. 2. Holding the gun by the handle on the top left of the gun, below the hose there is a little metal valve. Push that vent valve down and pull the trigger repeatedly until grease starts to come out.
If that doesn't work. Remove the grease hose, hold the vent valve down, pull the trigger a few times. Then release the valve and pull the trigger until grease comes out. Replace the hose.
And if that doesn't work. Sometimes when you put in a new cartridge the metal "washer" that actually pushes the grease up the cylinder will get caught at the bottom of the new cartridge. Make sure the washer will move freely into the cartridge.
That should do it!
Jan 14, 2011 | Lincoln Automotive Pneumatic Grease Gun...
Cant start the unit ,there is to much pressure on the pull chord when water is hooked up.
Trying to start a pressure washer with water supply on and gun trigger off will be a difficult task. It could be comparred to trying to start a lawn mower with the mower in tall grass. Place the mower on the drive or walkway and pulling the rope to start the engine is much easier. It is easy to start your pressure washer with no water in the system however there is a remote possibility that you could overheat the seals if you take too long to turn on the water. It is a little more difficult to start the washer with water supply on and someone holding the trigger to wand open. This will prevents pressure from building and making engine hard to start. You will not damage your washer if you start it with water supply off if you flood the pump and pressure hose with water first . Here is the procedure I use if i am working alone. I trun on the water to pump and open trigger to gun to allow water to flow into pump and pressure hose. Turn off water (leaving the water supply on will make it a little harder to pull starter). Start engine while holding trigger to gun open. When engine starts release gun causing unloader to activate circulating water in pump. Now turn on water and you are ready to work. If your system is under warranty however, I would advise to use the starting procedure outlined by mfg (hold open trigger to gun however). To get the longest life from unit try using it at say 75% of capacity or lower if your can and use max pressure on the tuffest jobs. Leaving your washer at full pressure for all jobs is like driving your car at 100 mph everywhere your go. Good luck.
Aug 24, 2010 | Northstar Professional Series Pressure...
My paslode wont shoot i cleaned the gun recently and oiled also the light is green and i compress the tip to shoot and it wont but the fan still comes on to vent the gas i also put a brand new gas in
strip it down again and put the battery in and whilst holding the nipple down pull the trigger (just mind your fingers as the fan will start) and as you squeeze the trigger see if sparks each time
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
No pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
Bushnell Velocity Speed Gun Logo
514 people viewed this question
Top Bushnell Baseball & Softball Experts
NOEL
NOEL
Thomas Perkins
Thomas Perkins
Are you a Bushnell Baseball and Softball Expert? Answer questions, earn points and help others
