I have a set of new gas (LP)fire logs just installed pilot will not stay lit manual says check flame to thermal couple but there is not a thermal couple visable. nor is it listed in parts manual. It is a set manufactered by desa charleston forge model#hrb3624pt
  • rlr5519 Nov 03, 2009
    no does not list nor does it have milli volt generator
    shows thermal couple as part of pilot assembly but I cannot find a place or I'm not seeing where it would go into thermostat control valve.
    Thanks for your inquiry.
  • frankrhoney May 11, 2010
    Does it list a milli-volt generator? This would be used instead of a thermocouple.
    Novelist:
  • 90 Answers
Also to add to last answer if the thermocouple looks burnt out like a crack or just burnt off it needs replaceing at a guess about 100 bucks for part and should be the same for labour to repair as should take about an hour to change
Posted on Nov 18, 2010
  • 89 Answers
The thermocoupleis about 3/16" in diameter and slides up through a hole right beside the pilot flame. Sometimes it doesn'tget pushed up far enough to come out the top into the flame. check the bottom of the pilot assemblynext to the silver pilot tubing, there the thermocouple is attached to a very small copper tube( 1/16") and this tube runs back to the gas valve. If it is there see if you can push iy up into the hole next to the silver tubing. unless the thermocouple can feel the flame the pilot will not stay lit, Hope this helps.
Posted on Nov 03, 2009
Keeps going out
If you just leave it on pilot and it stays lit....and then you turn the gas valve to on.... make sure you watch what happens, as if for some reason the flame doesn't stay on the thermocouple, could be angled wrong... it won't sense the flame and go out... it isn't the thermocouple, if the pilot stays lit when you let go of the button.
Jan 10, 2014 | Dyna-Glo (PPH16-LP) Utility Heater
I cant get my HRC200 gas fireplace logs to light.
the pilot flame must heat a thermal couple that develops a small voltage to open the gas valve. make sure the pilot flame is in contact with the thermocouple and hold the pilot start gas button on for at least 1 min befor turning it to the run position
Dennis
Nov 06, 2012 | Heating & Cooling
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
I have a evcon 7200erc S-1 The pilot will not stay lit.ignitor cycles while i hold lever to pilot,pilot lites i hold for 60 seconds release lever and pilot goes out.I replaced thermal couple to correct...
Check the following: Pilot orifice or line partially clogged --- remove and clean.
use a fine wire or drill bit to do this.
Gas control valve going bad --- replace gas valve. Gas valves cannot be repaired.
Sep 12, 2011 | Heating & Cooling
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
Have replaced to thermal coup.s and still cant keep the gas lit on mine? must relight it every time i need hot water, have had a tech out twice its now 2 yrs old and were still relighting the thing. no...
make sure coupling is in the flame and is mounted securely at all points.. and that it is tighten tight to gas valve..after that it could be the gas valve???
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
