Question about Samsung WEP-150 Wireless Headset
Samsung WEP150MBE not working
I plugged in my bluetooth headset for charging and all i got was a quick red flash then a green flash then nothing else. After an overnight charge I removed it from charging and pressed the button to turn it on but nothing happened? It seems something is wrong with the charging of the device?? Can anyone help?
Whats the answer i have the same problem
Posted on Nov 19, 2009
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Plugged in it flashes red, unplugged is unresponsive.
You also need to turn on your phone's bluetooth, and get them connected so that it works, otherwise, it could not.. Flash red means it's charging right now.
Android 4.0 Tablet PC
Jan 07, 2012 | Just Wireless Bluetooth Headset Wireless...
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
My nokia BH-215 is not pairing. The green light blinking continuously.
hello, clear setting or reset, to delete the pairing from the headset , press and hold the power key and the answer/end key (for about 5 seconds) until the red and green indicator lights start to alternate. to reset the headset if it stops functioning , even though it is charged connect the headset to charger while you press and hold the answer/end key , Ensure that your phone is on and the headset is off.press and hold the power key (for about 5 seconds until the green indicator lights start flash quickly. activate the bluetooth feature on thr phone, and set to search for bluetooth devices. select the headset from the list of found devices . enter the passcode 0000 to pair the phone. hope it works
regards
shaun
Oct 10, 2010 | Nokia Consumer Headset
How to charge WEP-150?
WEP-150, I put it on charge, as soon as I plugged it in, the light went red, then green, then it went off. It is not powering after leaving it over night. HELP!!!
Apr 16, 2008 | Samsung WEP-150 Wireless Headset
Samsung wep 150
I think i know why your bluetooth goes red then green. It is because your using a wrong charger like different make of the the charger or is it you never use it for a long time so is completely dead and you have to buy a new charger or bluetooth.
Nov 12, 2007 | Samsung WEP-150 Wireless Headset
Samsung WEP-150 Wireless Headset Logo
2,037 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
