Question about Dell Computers & Internet
Monitor intermittanly displays setup icons ..contrast etc then goes away/back what could cause this problen
  • 63 Answers
The menu setup button on your monitor is either shorted or already failing. Try to get it replaced/repaired if it's still under warranty.
Posted on Oct 01, 2009
The monitor goes off when i reset it displays vga
ok... this is your problem... if you wont fix this problen, after few months monitor wil not turn off.. i am not shure, but i see all time this problem..
Jul 08, 2012 | Gateway Computers & Internet
I get a pop up with a RED CONTRAST screen every few minutes It sometimes goes away if I push the contrast button on my Dell monitor. but it will usually come right back. I have tried everything to stop...
You can try the monitor on another computer to verify it is the monitor and not the display card at fault.
I'm assuming this is an LCD monitor. If you are sure the monitor is the problem, then your monitor's display driver circuit is probably getting close to failing. When one of the three colors (red, green, blue) becomes intermittent, the screen takes on the hue of the working colors. In your case it sounds like the blue is starting to fail.
A repair technician may be able to replace the circuit.
Jul 22, 2010 | Dell Dimension 4700 PC Desktop
Monitor problem
If you restart your computer and either go to the Bios setup menu (usually by pressing DEL or some other noted key, in the first few seconds of power up) does the same "contrast" menu still appear?
If so, then it must be your monitor (likely Monitor, not computer)
Your monitor is mad at you and it is displaying a Warning Message that is part of its OSD (On Screen Display). Some monitors are more sensitive then others so it takes very little to get this type of message. To get rid of it you will need to use the buttons on the monitor to get into the OSD menus. You need to look for something like "OSD Settings" or "Warning Message Settings" which may be found under "Setup Menu" or "Options Menu". This all depends on the make and model of the monitor as they are all slightly different.
Once you find this area you will need to turn off a setting that will be called "Warning Messages" or "Display Notifications", again the wording may be different but the idea is the same. Once you find the setting you should have the choice to set it to "ON", "OFF" or to an amount of time it will display (5 seconds, 15 seconds etc...).
On my Viewsonic the setting is found under "Setup Menu", and then I turn off "Warning Notification".
GOOD LUCK!!
ps. If the display looks OK then there is most likely nothing wrong. The message appears because the monitor detects a setting that may be in error. If the message goes away after a bit and doesn't bother you, you may choose to ignore it.
May 24, 2010 | AOpen A75PF Monitor
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Feb 06, 2009 | Dell E173FP 17" LCD Monitor
Monitor displays 'user mode' contrast icon @ 89%
Colin
If you can access the on-screen menu (see link below for manual) try and reset to factory settings.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00385928/c00385928.pdf
If that doesn't resolve the problem, then also check and see if any of the control buttons are stuck, (Press button them flick finger away to try an release a stuck button)
If issue still exists, you can consult a TV repair shop, but essentially, then monitor is uneconomically repairable and it would be more cost effective to just replace it with an LCD monitor
Jul 24, 2008 | Compaq CV 7500 17" CRT Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
