Question about IBM Wheelwriter 30 Typewriter
How do I remove the ball from an ibm selectric typewriter?
At the top of the Selectric ball there is or should be a rectangle in the plastic. This is a lever. Bend the lever until it is standing at 90 degrees to the original position. Give a tug on the lever. The ball should lift right out.
Posted on Oct 02, 2009
Size No. of Print wheel with a largest letters
Can you post the brand of your typewriter? On the old IBM selectric typewriters the Courier 10 ball would have larger print than the Courier 12 ball. Good luck.
May 03, 2016 | Office Equipment & Supplies
Broken metal wire in ibm selectric ii
You have either a broken tilt tape or rotate tape. One controls the tilting of the element (ball) and the other controls the rotation of it. If either one is broken, you will need a qualified technician to replace it and make any adjustment necessary so it doesn't break again.
Oct 17, 2013 | IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
Ibm selectric II typewriter prints a different letter than the one typed. the typing ball appears to be very sluggish.
By this time in thier life selectrics have become very gummed up which causes many many problems, you need a chemical cleaning and lubrication. It may be cheaper to buy an IBM Wheelwriter on EBAY.
DickyO
Mar 07, 2010 | IBM Office Equipment & Supplies
IBM Selectric II problem
Yes, I did bring a small screwdriver from home and removed the ball. Thank you for your assistance.
Feb 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
368 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
