Question about Canon PIXMA MP160 All-In-One InkJet Printer
Is this printer a network printer - Canon PIXMA MP160 All-In-One InkJet Printer
  • 63 Answers
You could not connect it directly to a network AFAIK but you could connect it to a computer connected to a network and then share it so other computers on the network could use it.
Posted on Oct 01, 2009
  • 20 Answers
No. It does not have ethernet nor does its software allow you to share printers. There may be a third party solution...
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
on Dec 06, 2009 | Computers & Internet
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
How to install network printer
on a server ?
Make sure the networked printer is turned on and connect to the Internet using an Ethernet cable.
Click "Start" on the server computer and click the "Printers and Faxes" icon.
Click "Add a Printer" on the left side of the window.
Choose "A Network Printer" from the pop-up window, and click "Next."
Type in the exact location or Internet Protocol (IP) address of the networked printer, and then click "Next."
Select the printer manufacturer and model from the list of driver options. Click "Finish" to complete the printer installation process.
or a home network
Navigate to the Control Panel and click on "Printers and Other Hardware."
Click the printer you want to share in the Printers and Faxes folder. Click on "Share this Printer" in the Tasks Pane or right-click on the printer and select "Properties.
Open the Sharing tab and click on "Share this Printer." Enter the name of the shared printer and click "OK."
Use the shared printer with any computer on the network by navigating to Control Panel > Printer and Other Hardware.
Click "Add a Printer" and browse for the network printer you just shared.
Connect the Printer Directly to the Network.
Plug the printer directly into the network hub or router.
Follow the instructions for setting up the printer for networking provided by the printer manufacturer.
Click "Add a Printer" and browse for the network printer.
hope this helps
Sep 27, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Installation network printer
on a server
on a home network
hope this helps
Sep 27, 2012 | Canon Ir 3300 Black & White Copier
How do i install laserjet printer p4015n on a network
put the printer on
connect a straight cable from printer to your switch in network
now read the instruction manual the default ip is written over there
note it
now from any system in network
open network connections click on properties
goto tcp/ip
click properties
click advance
in tab-ip setting add any other ip of same class which was printer's default ip
ex- if printers ip was 192.168.0.1 add 192.168.0.7
now apply all settings
now on the same computer type the printers ip in any browser
this will give the access of printer to you
change ip setting according to your network class
i.e. assign the printer your network class ip
now you can access the printer from any system in network
do one thing that put drivers of printer in some sharable drive on the network
now you can goto any system add printer from control panel
select network printer
select the printer
when prompted provide location of drivers of printer
you are done .
Feb 08, 2011 | HP LaserJet P4015N Printer
How do I set it up for wireless
Install a printer on a home network The most common way to install a printer on a home network is to install it as a stand-alone device on the network, and then add a connection to the printer on each computer that is on the network.
If you're not sure what type of network printer to install, decide if you want to:
  • Use a wireless printer. These printers use a built-in wireless card and plug into a power source, not your network or computer. After you turn on the printer, you need to refer to the information that came with the printer to set up a wireless connection to each computer on a home network. Security options for wireless printing are determined by each printer manufacturer.
  • Connect a printer directly to the network. To do this, you need to plug in the printer to your network hub or router. How to install these printers depends on whether the printer and your network device use an Ethernet, universal serial bus (USB), or another type of connection. You also need to refer to any installation information or tools provided by the printer manufacturer.
  • Connect more than one printer directly to the network. To do this, your hub or router must be able to support more than one printer connection.
Hide all expcol_imgs.png To install a network printer
  • To find out how to install a network printer, check the information that came with the printer.
expcol_imgs.png To connect to a network printer After you have installed a network printer, you need to add a connection to the printer for each computer on the network.
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. On the toolbar, click Add a printer.
  3. In the Add Printer Wizard, select Add a network, wireless or Bluetooth printer, and then follow the steps in the wizard.
Feb 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
HP Laser Jet 4700 network card
HP LaserJet 4700 printer comes with inbuilt network card so you don't need to install another network card. If you want to but network card for your PC then go for 100/1000 Mbps network card.
Regards
Ashly
Feb 03, 2010 | HP LaserJet 4700 Printer
How to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Dec 22, 2008 | Lexmark E120n Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
113 people viewed this question
old marine
old marine
