Question about GE Advantium SCA1001HSS Convection Microwave Oven
Change fuses on Advantium 120 model # SCA 1001 HSS 01
Hi, Thank you so much.
We have model # SCA 1001 HSS 01 built into an old cabinet making it difficult to remove.
A few days back it shut down mid cook cycle. I am told it's possible to check and change one of the two fuses without taking the unit down. Is this true?
I have access to the front side, under side, and right side. The rest are a nightmare to reach.
I bought the fuses wb27x10471 and wb27x10388.
Please let me know if there are step by step diagrams for this servicing as well.
2 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: GE Advantiumk 120 - Complete
There is a filter board assembly in these machines that does have a 20amp one time fuse. However i will say that normally this is not the problem with these. That fuse normally will blow due to the main control board. The fuse is bnot that hard to get to thou if you want to check it. From the top of the unit remove the screws holding the front top grille in place. Then holding the grille slide it left a little this will unlock the grille and then you can take it right off. From there the fuse is mounted on a little board on the right hand side of the microwave. You will see it towards the top of the unit mounted to the inside wall. However if you find that this fuse is good, since the unit is new i would call your number in your owner's manual for service. Microwave's can be very dangerous to work on, any thing beyond the fuse call a professional. The unit is still under warranty. Either you can check the fuse or call the manufacturer and have the tech when he comes show you where it is.
Posted on Oct 03, 2009
My SCA 1000 completely shut down and won't come back on
There is probably an internal slow-blow fuse,they will electrically fatigue over time.It will require the cover to be removed to replace it,look for an inline fuse holder on the hot lead where the power cord enters the housing.
Dec 19, 2012 | GE Advantium 120 Convection/Microwave Oven
How do I change the light bulb in my Advantium Micro Wave. Model is a 120 number SCB1001KSS01. Please send me instructions. Thank you. Karl kflorian5@gmail.com
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2011 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantiumk 120 - Complete Blackout Model Number: SCA 1001 HSS 01 Brand: GE Age: 1 - 5 years Thanks a lot for your expertise. It's a total blackout mid cook cycle. The house breaker and...
the fuse is located on the control panel which is at the back of the base.and control panel, is located at the top.the fuse is not on the control panel its located on the control board.you will just have to remove the oven.this is the only procedure.but once the unit is removed then its not to tough.the sides are just fitted by screws.as replacing the fuse from control board also called main board is very simple.you just need to pull the fuse out by a plyer/clipper or with a thin knife.fitting is also easy there is a fuse holder.just keep the fuse on the holder and slowly press the fuse without applying force.it will fit easily.the cost of fuse is near to $3.you can get it from ------ www.radioshack.com ------ if the fuse is ok then its time for new main board. you can get the parts from www.partselect.com ------------------- this will help.please do rate the solution.thank you for using fixya.keep updated.
Oct 02, 2009 | GE Advantium SCA1001HSS Convection...
MICROWAVE JUST QUIT
THERE IS A FUSE INSIDE THIS MICROWAVE IT MAY HAVE BLOWN. HAVE SOMOENE THAT CAN OPEN IT UP FOR YOU AND CHECK OR CHANGE THE FUSE.
Apr 11, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium readout flashing
I would say it is a sign of trouble.
Not to say that it's catastrophic, but on these models part can be pretty expensive.
We regularly repair such control units for customers nationwide by mail for in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
Advantium 120 Complete black out
Since you've already checked the fuses, my next suspects would be the thermal cutouts (or thermostats or thermal fuses, depending on your exact model number). One would be located on the right side of the chassis right above the magnetron. The other would be located on the left side of the chassis. It's the flame sensor. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Advantium 120 is not actually the model number - you have to look on the tag around the door or inside the cavity for that. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk I appreciate your thoughtful rating.
Apr 15, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA1001HSS Convection Microwave Oven Logo
344 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
