Tv flickers when close up on picture and when writing comes up . if i press the information botton on my skt remote when i bring it up on the screen that flickers like crazy.
    Novelist:
    Champion:
  • 210 Answers
Check that your cable connections are pushed firmly in on your TV and the source that you are coming from, and also check the condition of your cables, if they look odd then replace them.
Also, change to different socket on your TV for your source i.e if you are plugged into scart 1, change to scart 2.
Also, do a full reset on your TV.
If none of the above works, a cable maybe loose inside or you may need a new video/mainboard inside.
Thanks
Posted on Oct 01, 2009
How do I make my screen smaller to fit my tv screen?
Hi Sharon, on your remote there's probably all sorts of buttons like menu, guide, blah,blah...you get the picture(no pun intended ha)there is a format button too. Turn your tv on, press format and across the bottom of the screen it will display what "format you are in. Wide screen, crop,etc most of these models will tolerate what's called 1080 pixels. Keep pressing the format key until your desired "format" diplays (please don't be alarmed if your screen flickers a few times it's your computer and tv talking and readjusting the picture for you) You should be able to just exit and you will see all of the picture within the screen. Be well.
Sep 29, 2014 | RCA HD56W66 56" HDTV
Hisense tv
The problem with these poorly made (in my view) sets is they are made in China and the company there has gone out of business by my count 2 times---they make poor sets for export and no parts or service literature so when you replace it consider another brand and something worth being repaired.
May 24, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
A black rectangle appears in the bottom half of the screen. The rest of the picture is fine, the sound is fine. The box goes away if i press the menu button - but it comes back again. What is wrong?
Do you have a cable/satellite box connected to this tv?
Try this first it sounds like you have the closed caption turned on by accident.
On the remote press the MENU button.
Use the navigation keys to move the selector to CC and press OK.
This should bring up the Closed Caption sub menu.
Ensure that the closed caption is set to OFF
Thanks,
Robert
Feb 26, 2011 | Vizio M220VA 22 in. LCD HDTV
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
29 inc flat tv flickering
maybe your tv screen has a problem much better if you bring it to a tv technician.
Jul 30, 2009 | RCA TruFlat 27F520T 27" TV
Bush tv 20" lcd tv LCDS20TV006/A - blue screen no picture availab
DOES THE MENU SCREEN COME UP? IF YES TRY ANOTHER INPUT. A BLUE SCREEN IS USUALLY INDICATIVE OF THE SET NOT SEEING A VIDEO SIGNAL.
Apr 10, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Menu on remote will not work
If you are saying the white square is coming up when you are viewing TV it sounds like the closed caption is on, try o turn that off first. If that is not what you are describing then I am lost as to how an original remote does not have the funtions on it that are required to navigate the system
Feb 27, 2009 | Televison & Video
Have a daenyx dv-833 dvd player
Good Morning,
Your connection is very easy so we should not have a problem isolating the problem.
We just have to go slow step by step.
First lets just check the Yellow cable just to be on the safe to side sure it is connected properly on the back of the DVD player and on the Televison.
Second, If the connectionn is secured. Turn the DVD player on, make sure you do not have a disc in the tray then turn the DVD player off.
Make sure the battery on the remote control is a fresh new battery (process of eliminattion).
Hold the remote control in front of the DVD front panel.
Turn the DVD player on with the remote control. Look on the front panel of the DVD player, it should read no disc. Press the Pro.Scan button "once". (Have you notice a flickering on the Television Screen).
If no flickering on the TV screen, press the Pro.Scan button again, ( this will be the second time). Have you notice the flickering?
If not, press the Pro.Scan button again ( third time). Have you notice a flickering on the TV screen?
Did you not notice on the LED of the DVD player if it read anything when you pressed the Pro.Scan button?
Try the above procedure again if your picture did not resume. If the picture resume in black and white, do not press the Pro.Scan button anymore.
Let me know the outcome up to this point.
Thanks,
Mike H.
Nov 02, 2008 | Televison & Video
The picture has a pink and reddish hue
Any magician can make a trick look easy - but NOTHING replaces years of training and experience. That said, here's your answer:
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button. Then press the POWER button for two seconds. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice)
Scroll down to: “TA1383” then (Arrow right)
Scroll down to:
CONTM1: _______
CONTS1: _______ (Press exit)
After writing down these values, please continue:
Nov 11, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Locked!
Turn on the TV With the remote press the F button and the Mute button at the same time. This should bring your TV back to normal mode. from Don "the TV King"
Jun 04, 2006 | Apex Digital AT2008S 20" TV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
