Question about Music
Hi. When switched on the speaker makes a loud constant crackling sound. Nothing will work, no keys, stops, anything. Just a loud crackle!
  • 26 Answers
This usually means that the speaker is blown. Try running through a different setup and see if it fixes the problem. Hope this helps
Posted on Oct 01, 2009
My TH-15A starts making VERY loud crackling noises after a few minutes of being turned on. It does not matter if an XLR cable is plugged in or not, and the volume control does not change the volume of the...
buy a canister cold spray and spray on some active components if the noise begins You have a thermical failure in a component on the board can be faltering resistorcircuits or resoldering some active components.
May 08, 2016 | Mackie Tapco Th15a Thump Active...
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
My behringer b203a is making a loud muffle mono feedback sound when i am trying to use it. what could be the problem? please help!
this is normaly a wiring or amp issue. if it was the speakers they wouldnt make any sound or they would crackle or buzz
Jan 31, 2011 | Behringer B3031A 2-Way Active Studio...
Left speaker making a crackling sort of vibration-sound especially on certain tones. Is the speaker shot?
Hi, I think the speaker is getting damaged. When you strike hard keys, it makes crack sound i guess.
If you can open the keyboard and test the speaker by using a battery and run a wire to the positive and negative spot of the speaker. If you hear a clear sound after testing the speakers, that means the speakers are working properly,but if it does not sound clear enough,that means the speakers are not working well...
When a speaker does not sound good enough, it's usually a sound IC problem that will need to be replaced.
Hope that helped.
Feel free to pass your comment.
Thanks for using fixya...
Jan 14, 2011 | Yamaha CP300 Stage Digital Piano...
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
Yamaha Gran Touch problems
bit late. I have had the same problem. I replaced the optical module which solved the problem for me. The optical module is located above the keyboard and is used for scanning the keyboard.
Good luck,
F van Duijvenvoorde
Mar 12, 2010 | Yamaha Full-Size Keyboard
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
173 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
