Question about Homelite 'Yard Broom' Leaf Blower
Rebuilt carb need air and idel mixture screw settings. Blower runs but only a few seconds and then will not restart.
    Problem Solver:
  • 7 Answers
Air fuel mixture screw shoould have initial setting of two turns out from lightly seated,check unit make sure cylinder is tight to base they only have two screws holding them down,if 2 cycle motor has a vaccum leak they will not run properly,also check compression if you have gauge should have a least 100 psi to run properly.
Posted on Oct 02, 2009
Simplicity 16hp Briggs stalls
Check the slow running jet for glogging, set the mixture screw 2 turns from fully closed and make sure the small filter connected to the fuel tank is not blocked.
Mar 29, 2014 | Simplicity Garden
Virago 750
Your Air/Fuel Mixture is wrong.. Your carb is getting too much air and not enough fuel. Have you adjusted the jet screw setting? Does it have one?
Jul 19, 2013 | Motorcycles
I just put on a new rebuilt carburator on my 460 v8 1987 xlt 250 ford truck 4 WH. drive. its a motorcraft stock holley. I cant seem to find a way to ajust it. Wont run smooth or idle? It was set up for...
You have two setting screws on front of carb, You start off by adjusting all the way to the left, Then back off 3/4 turn to both setting screws, Then you have to set your air fuel mixture by just slowly turn your setting clock wise do so until vibration go away. Sorry there is no easy way to explain, Good luck to you,
Apr 03, 2011 | Ford F-250 Cars & Trucks
My Honda 13.5hp engine has started surging. It seemed to occur after the air filter fell off during mowing for a few seconds. I have tried cleaning the carburator but it still surges. Anything else I can...
Hi sndlys,
When the engine surges (we call it hunting) like that it usually means, the carburetor or the governor need adjustment. You have cleaned the carb. but did you clean or replace the air filter, and did you try to adjust the carb? Since it was running good before I doubt it is the governor. Try to adjust the high speed mixture screw by 1/8 turn at a time and waiting a few seconds to let that adjustment work it's way in the carb. Start by turning the screw out (counterclockwise) a few times. If nothing happens or gets worse turn the screw in (clockwise) a few times, but do not go less than 1 turn out from a lightly seated position. (turned clockwise until lightly seated so no damage is done to the seat or the needle screw) to prevent running in too lean a mixture to prevent overheating and possible engine damage. You could try the low (idle) speed mixture screw adjust a bit, but make sure you remember the position you started from whenever you any adjustment at all. I think if the carburetor is clean and the air filter is clean, also that there is a good fuel flow to the carb. you should be OK. I hope this helps out a bit.Get back to me if you need help. All the best and good luck. Denis.
Mar 02, 2011 | Honda Garden
Runs for about 20 seconds then dies. will run at low idle but when you increase throttle it dies after a few seconds. already cleaned carb, just had it rebuilt last year. i noticed that when it dies the...
I would check the govoner spring, maybe it is worn out or isn't on correctly.
If this isn't the case I would check the fuel air mixture screws if your carburator has them, maybe it is getting too much fuel when the throttle is turned up.
Apr 21, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Does the pilot screw alter the air intake on the Carburetor of a gsxr 750 slingshot 1988 model
Certainly you best adjust these screws with a vacume gauge set connected and set them all the same as the gauges dictate as the number of turns out is just where you start. The sync needs to be set first with the idel turned up too high when it's right turn the isel back down and check again as the idel is low nows the time to correct differences with the idel mixture screws. As the idel mixture is always on they effect the total mixture at all enf=gine speeds but lesser so at high speeds only noticeable at the gas pump carefully cheaking
Dec 04, 2009 | 1988 Suzuki GSX-R 750 J
Leaf blower starts and runns ok for few mins then
Target your inspection towards the 'spark arrestor screen' in the outlet of the muffler.
Overfuel or 'rich' condition
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Nov 13, 2009 | Craftsman Garden
HARLEY DAVIDSON 125TX WILL NOT START
replace plugs also on carb there will be a mixture screw the person probably adjusted this you need to turn this out and see if it improves 1/2 a turn if not screw it in 1 turn if still no difference fiddle with it also replace/clean air filter this may help good luck bud df7e911.jpg
Sep 09, 2009 | 2002 Yamaha TT-R 125
High idle on start up with choke off.
This sounds like an air leak is making the fuel/air mixture too lean. Any air leaks between the carb and the head will lean the mixture. Old, hard and cracked rubber manifold parts are the usual culprits. Old gaskets and "O" ring seals can leak air also. A bad head gasket seal happens at times also, as does an exhaust valve not fully seating. Air leaks are the idle speed problem.
A different problem is likely present in the carbs and that is what is causing the rich fuel smell. The carbs must be balanced. Example > If three of four carbs are perfectly balanced and one carb is not, then the 3 are "driving" the 4th carb. This will cause gas to spit into the air cleaner from the "bad" carb and can cause a backfire or two. Special vacuum gauges are needed to balance the carbs. Also be aware the carbs must be scycronizsed as well. The slides on all four carbs must lift at exactly the same time when the throttle is cracked.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
I don't get paid for my answers but I do take pride in them, and I am only trying to help. So if you will, > > A “very helpful” rating for these answers? Thanks!
Jun 14, 2009 | 1977 Suzuki GS 750
Idele / mixture screw adjustments
You'll need a handheld tachometer or tach/dwell meter if your car does not have a tachometer.
Start by adjusting the idle screw to the correct speed (do this with the car running) allow a few seconds between adjustments for changes to take effect. I don't know the specific speed for your car, but 800-900rpms is a good catch-all setting.
Next adjust the mixture screw open. Your idle speed will gradually increase as you open the mixture screw. Again, allow a few seconds between adjustments to check the results. I like to count the turns of the screw as I make them. I will usually make adjustments 1/4 turn at a time and count, so that if I adjust too far I can go back to a setting that I know worked.
Continue to adjust your mixture until it no longer causes the idle speed to increase, then take it back about 1/8th of a turn.
Now readjust your idle screw back down into the 800-900 range.
A word of advise before you start- carb tuning is pretty much last resort when troubleshooting your vehicle. In order, you should make sure all of the following is done first:
Visually inspect all vacuum lines for cracks, holes, or disconnections.
Check ignition components (plugs, wires, etc) I will check the wires by letting the car idle and misting water around the wires. (using an old pump hairspray bottle or water bottle, etc) Watch for a little fireworks show. This is easiest to see when it is at least partially dark in your work area.
Next check to make sure your ignition timing is within spec.
Apr 05, 2009 | 1988 Toyota Corolla 4 Door
Homelite 'Yard Broom' Leaf Blower Logo
184 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
