Question about Panasonic DMR-EZ48VK DVD Recorder
When I try to record a program there is a flashing red rec light and the numbers don't change but it says it is recording but nothing is recorded
It was fixed by reprograming the tv stations
Posted on Oct 02, 2009
How do i record with my dvd player/recorder?
You have to go to Menu Page select timers and from there you can record your programs to record at any time. If you are watching something you want to record click on REC on remote it should have a little red dot on the button,then it will take you to where you program how long you want to record.
Hope this helps Donna
Feb 19, 2011 | RCA DRC8052N DVD Recorder
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Don't know how to actually record
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Can't record a program with videotape
Try setting the clock again paying close attention to AM and PM settings as well as everything else. REC/OTR is for recording "on the spot". Make sure unit is in proper mode with the DVD/VCR button. Customer service number is usually on a sticker on these units.
Mar 10, 2007 | Sansui VRDVD4000 DVD Player/VCR
Recording
The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
Jan 26, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Problem recording
Jan 26, 2007 | EverFocus EDSR1600/500
Panasonic DMR-EZ48VK DVD Recorder Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
