I have a Canon Pixma iP1700 printer. When I try
I have a Canon Pixma iP1700 printer. When I try to print multiple page documents, the rollers feed multiple pages at once.
  • 615 Answers
This is a common issue with all printers and faxed. Try to clean the rollers and use different paper weight
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Posted on Oct 01, 2009
Testimonial: "Thank you."
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Why can't it print more than one page at the time
You could try to clean the paper feed roller. Please follow these instructions from Canon support: (copy and paste this link into the location bar of your browser)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11865
Type question: "How do I clean the paper feed roller"
Click "Search" button. Review solution.
Dec 05, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Printing only upper part of page - big graphic PDF
1: check in the printer properties( page setup ) is it latter then make it A4
2: clean the roller
3: also when u printting check with uper try not from try 2
if its printing proper then try is touching roller
Mar 25, 2009 | Canon PIXMA MP540 All-In-One InkJet...
PIXMA MP780: Multiple pages feed together
Most paper feeding in printers is done via rubber rollers. These rollers get dirty and over time, the dirt glazes on to the roller. When this happens, the roller loses its grip. If you look at the rollers they will actually look shiny. After a while the rubber will dry rot and it becomes a more frequent problem. Try the following:
(EASY/LIGHT CLEANING) Get some inkjet cleaning paper at you local office supply. This is usually a thick absorbent paper that you spray with a cleaner and "print" with the wet page.
(MEDIUM) If that fails, unplug the printer and try using rubbing alcohol or ammonia to rub the rollers with a terry cloth. Be sure to rotate the rollers and get them all the way around.
(HARDER/BE CAREFUL) For hard glazed dirt, you may want to carefully use an hobby knife to scrape it off the rollers, being carful not to damage the rollers. Follow up with alcohol cleaning described above.
Feb 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My canon pixma ip1700 will not print. One page of my document printed and the second page refuses to print.
did you see the indicator light?
i have the same problem and the solution is try to replace the mainboard to a new one.
Jan 16, 2009 | Canon PIXMA iP1600 Printer
INSTALLATION OF CANON IP1700 PRINTER
If you do not have the disk you download software from Internet, follow instructions below,
Click here:Pixma ip1700 Canon Drivers and Software
A web page will open, follow instructions, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some printer does not work on Vista.
Sep 23, 2008 | Office Equipment & Supplies
I dont have a cd to install my Canon pixma iP1700 printer. Can u please help me. Thanks
iP1700
Aug 10, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Canon Pixma iP3300 printer
Problem solved. press and hold the RESUME button on the printer (just below the power button) until the power button flashes green three times. Release the RESUME button and the paper roller will automatically clean itself. Do this twice and it should work perfectly.
Feb 20, 2008 | Canon PIXMA iP3300 Printer
112 people viewed this question
k24674
