Question about Whirlpool GY396 Electric Kitchen Range
Control panel on gw395leps00 will show power failure
Control panel displays the error code for power failure when there has been no loss of power and remains even when power has been reset. Sometimes it will go into power failure mode numerous times in a short period of time even when the over is not being used. Is this a quick fix, or is this going to cost me?
Not sure if you need to replace your control panel, but if you do, you'll need this part http://www.repairclinic.com/SSPartOnly.aspx?PPStack=0&pop=1&ShHd=0&ShFt=0&PartID=1257027
your original "membrane switch" seems to have been replaced with this new (improved?) style. it fits your range and will presumably solve any short circuit problems you may be having with your original touchpad/membrane switch
Posted on Nov 10, 2009
What is an E3 code on a Culligan Medalist Series?
https://www.manualslib.com/manual/859287/Culligan-Medallist-Series.html?page=8
Quoting from link to free manual shown:
FAILURE MODE
There are certain conditions that can be interpreted by the circuit board as a failure of the drive motor or motor
position switch. Upon failure detection the control will cease further operation. A telephone hand set symbol will be
shown in the upper left corner of the display and the error code will be shown. Listed below are the different error
codes.
1. Motor Always Turning
Error code "E1" occurs when the circuit board detects changes in the motor program switch when the motor is
not supposed to be turning. The phone icon and "E1" will be lit in the display.
2. Motor Never Turns
The Culligan Medallist Series control is equipped to detect no change in the motor position when the motor is
supposed to be turning (motor or piston locked in a frozen position). The AccuSoft circuit board will apply
power to the motor for 20 seconds. If there is no change in the motor homing or position switch, the control will
power down for 1 minute. The circuit board will repeat this procedure two more times in an attempt to remove the
obstruction. If no movement has been detected, the control will permanently power down and a phone icon and
an "E2" will appear in the display.
3. Homing Error
Error code "E3" occurs when the circuit board detects when the control is unexpectedly in the home position.
The phone icon and "E3" will be lit in the display.
Error Display Cancellation
The error code display can be removed by removing the power to the control for 1 minute. After clearing an error
condition, the control will default to the factory settings when power is restored.
Apr 21, 2018 | Culligan Measuring Tools & Sensors
Tip
Whirlpool Calypso Dryer Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
  • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
  • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
  • 60 degrees F. - 15.3K ohms.
  • 70 degrees F. - 11.9K ohms.
  • 80 degrees F. - 9.2K ohms.
E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
  • This error code is displayed only in diagnostics mode.
on Jul 19, 2010 | Washing Machines
F2 shows on display on whirlpool gas stove
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
May 14, 2014 | Whirlpool RBS305PDS Electric Single Oven
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Error code 0xc004e003 in windows 7 ultimate,wat can ido
Welcome to FixYa!
I assume that this error code is showing in the Display Panel your printer.
Reset your printer.
Without turning off the product, disconnect the USB cable from the rear of the product.
  1. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
    1. Remove the cartridges from the product.
    2. Wait for the 'Insert Cartridges ' message to display on the control panel.
    3. Disconnect the power cord from the back of the product.
    4. Wait 60 seconds.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
    6. Reinsert the cartridges, and then close any open doors on the product.
    7. If you receive a prompt to print a calibration page, do so.
    8. Reconnect the USB cable to the rear of the product, and then try printing again.
    I hope this helps.
Thank you for using FixYa!
Jas247
Mar 29, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My HP Photosmart C6380 All in one printer , won't print. It reads ink system failure. With a code 0xc19a0036 Could you tell me what might be wrong.
The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .' c01733891.gifImportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error: Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 26, 2010 | Computers & Internet
Whirlpool wmh1162xvs service code F6 after power failure
This is almost always a shorted microwave power relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 14, 2010 | Microwave Ovens
Whirlpool Duet will not work
Hi, you could have a control fault here or a door lock mechanism failure as well. the best way to find out if its ether the control or the door lock that may be faulty, is to unplug the unit for 5 minutes. this will drain all power from the control board, in return, resetting the program.
After the five minutes are up, simply switch your circuit breaker to the on position or plug the unit back in. If the control is working correctly, you should see a error code that says FdL(Failed door lock). If the control simply continues to malfunction like it was previously, this will confirm a major fault within the control board(microcomputer).
In this case, you will have to replace the control board in this unit. Remember, after the reset, power up the unit and watch the led and control panel carefully for any error codes. if the error code display is not functional, it will confirm control failure.
If you get an error code(FdL), check the wiring harness that connect the door lock mechanism to the control board. make sure they are in good condition and not lose. if the wires are ok, replace the door lock mech.
Please rate and god bless:)
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
My printer dont want to print
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Whirlpool GY396 Electric Kitchen Range Logo
320 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
