Question about Nokia 6255i
Nokia 6255i (or 6256i) Verizon
Mic. died, ordered new one and replaced it, and still nothing! Can only use bluetooth or wired headset. Its a troubling problem, can't pick up audio for video or use speakerphone,or voice record. Please help!
  • vancona Jan 10, 2008
    keerti, what is meant by "tracks"?
    Problem Solver:
  • 4 Answers
Check the tracks of mic to headphone
Posted on Jan 08, 2008
Cannot store voice tags
Delete some SMS and you will have more free memory to add a tag to a contact that you must save on the telephone and not on the SIM
May 20, 2014 | Nokia 6275i 6101 6102 6102i 6103 6133 6126...
LG Headset can pair with PC and I can hear but the mic is not working
I have this sale problem. I am using a rocketfish micro dongle to connect my LG tone to my PC and I can hear fine. However, when I set the bluetooth mic to default, I only hear these random blips and pings and it shows nothing received in the audio bar.
Feb 04, 2013 | LG hbs-730 Tone Stereo Bluetooth Headset
Whats the default security code for nokia 6256i ? how to reset it ?
the default code is 12345...in order to reset it you must go to settings-reset to factory settings....i hope is the right path i don't know his menu
Feb 11, 2011 | Nokia 6256i Cellular Phone
Most people I try to talk to using the bluetooth complain that they can't hear me even whn I almost shout.
It could be that your mic is clogged up or dirty, or that you have a loose or broken wire. No way to know. If you try to clean the mic with a damp cloth, do not run it under water. Surgery drinks will leave crystals in the mic, which do not allow sound through. If it still won't work you may need to replace the headset.
Good luck from Headsets Direct!
Sep 28, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Motorola Bluetooth S9 Wireless Headset Not Connecting to LG Voyag
You have to go to Verizon, I had the voyager and the S9 headset, the S9 didnt want to pair, so they checked the bluetooth witch was'nt working, so the gave me a new phone right then and their, and it worked fine!
Nov 27, 2008 | Motorola Mobility Bluetooth Hands Free...
Am having problems with setting up my bluetooth headset for ps3
the problem of it is compatibility here's the step1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions.
  • All makes and brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 4. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
  • All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Nov 13, 2008 | Video Game Consoles & Games
REPAIR NOKIA 6255I
bagaimana sih format nokia 6255i, menggunakan *#7780# masih aja tidak hilang applikasi yang ada di hp
Jan 17, 2008 | Nokia 6255i
Nokia 3250
Get a new phone, hope you have insurance, or pray it's under warrenty. Face it the mic is dead
Jan 17, 2008 | Nokia 3250 Cellular Phone
Nokia 6255i Logo
85 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
