Question about RCA 25423RE1 Phone
We have the RCA 25423/24 base unit and we have three lines coming into our company. Two lines work together and the third line is independent (different phone number) I cannot get the lines to work together. We can only use one phone at a time. Please advise. jcarmichael@niswonger-reynolds.com
Took the system back and bought a different system
Posted on Oct 02, 2009
Getting check tel line message on base unit. Checked all the plugs on handsets, but still get message.
It could be one or more of these:
- the cord that goes from the base unit to the phone company wall jack is faulty
- the cord that goes from the base unit to the phone company wall jack is not connected or is not plugged in to the base unit jack labelled 'line'
- the wall jack is not active (ie; does not have phone company dial tone)
Sep 04, 2017 | Lands Phones
These phones have worked well for a long time . However, all of a sudden I hear static noise on all of the handsets. Is it possible to get rid of the static noise short of replacing the units?
Check your phone line or have it checked by your phone company. Three phones do not all go bad at the same time, do they?! Of course not!
Hook up another phone and see if it also does the same thing. If so definitely the line. If not, then it is the base unit of the three some that has an issue.
Sep 21, 2015 | Panasonic KXTGA101S 3 Handset KX-TGA101S 3...
I am looking to buy a A495H base Gigaset unit to work with my 3 unit A49H phone set
Most modern Gigaset units work together.
I have a pair of gigaset 300 phones and three newer models, and a BT Diverse 2000 phone, all talking to the same DECT base station (a VOIP N300IP).
Feb 12, 2015 | Siemens Gigaset A495-4 4 handset cordless...
We have two newly purchased base units that can't pick up a line that has been placed on hold by the main reception desk phones. If you try to pick up a line that is open from these phones, they work fine....
You can't pick it up on another unit unless it is transferred from the original phone. I HATE that about this system. I have a question - we are trying to use a second base unit and are having a terrible time getting it to work right. Is it possible to use more than one base unit?
Jan 11, 2011 | RCA 25450 4-Line Extended Range Multi...
When removed from cradle and then dial it gives a beeping sound and does not dial or have connection sound.
First, does the base have power? Is the handset fully charged and recognized by the primary base station (for a multi-handset system)? Is the base station plugged in to a working phone line (I like to use an old corded phone for checking this - listen for dial tone first)? Is the phone cord to the base bad (try a different cord)? Does your phone work with the base plugged into another phone jack? If you can, check if the incoming phone wiring is working (there should be a box where the utility comes in that can be opened - plug in a test phone into the test jack there).
A bad jack is indoor wiring and you will be responsible for fixing it. (Depending on the faceplate, these are either multiple wires to screws or a terminal block. The screw type can be overtightened and break one wire.) If it is a problem at the utility box, your phone company should do the service.
I hope this helps.
(I've lost phone service at the box on one line of a multi-line home for unknown reasons and lost all lines due to a bad backhoe operator. Both were fixed asap by the company. A third outage only affected the dsl and was lightning strike related - damaged a noise/interference block.)
Mar 09, 2010 | GE 26921GE1 900 MHz Cordless Phone...
I'm setting up a side rack of equipment i would like to incorporate into the tascam. I want to use an effects unit,bbe sonic maximizer a tc helicon harmonizer and possibly an parametric eq. I'm not sure in...
Get a dbx 400x Program Route Selector or something like it. (eBay). It will allow separate independent attachment and selection via front-panel switches of three processors and three tape decks to a single Tape Monitor loop; and the processors can be placed either before or after the processors or source, again via switches. If you have more processors you can always line some of them up in-line on a single processor loop. I do it on mine.
Feb 06, 2010 | Tascam 2488 Portastudio Multitrack...
Pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
Apr 09, 2009 | General Electric RCA-25424RE1 4-Line...
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Four way calling
When you conference two lines or more together you get what you call line loss which makes the audio levels deteriorate. So to conference yourself and three others properly you may have to try a few different options to get the performance you want out of the conference call. Many phones/phone systems have three way calling which connects you and two others, so depending on the calls you wish to connect, an option would be to have one of your callers actively participate in the conference connection procedure. For example. You have a two line phone with a conference feature. So you call person A on one line and person B on the other, then hit the conference key. Now you have "Y" (yourself) and person A and B speaking together via the conference feature on your telephone. Now all you need is person A or B to have the same two line setup with the conference feature and they make the third call to person C and hit their conference button, now all four (Y,A,B&C) of you all talking together. If it is not possible to have one of the callers do this, you will need to have at least three phone lines and a phone that will enable you to have four way calling. However, you may want to dial 611 from your telephone, and try to get to a service rep., your local phone company may have some options for you. However, rather than investing in costly phone equipment, it might be cheaper to use a call conferencing service. They are fairly cost effective, and you basically have the three other partys call a toll free number at a specified time and you call get conferenced together for a fee. And last, you may want to research some VOIP options if all the partys have high speed connections. Good Luck
Feb 10, 2008 | Lands Phones
RCA 25423RE1 Phone Logo
617 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
