Tried removing card and swithced the lock back and forth, trying it both ways. Nothing! Tried formating the disk, but skips that option in the menu area. Tried resetting the camera to factory settings. Nothing! Then tried a new card, but still recieved the same message. Any suggestions?
SOURCE: Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
SOURCE: my nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
SOURCE: "memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: when switched on camera gives message - memory card is write prot
