Question about GE JGRP17 Gas Single Oven
Due to a spill the ppilot lights are out on the burners on one side of my GE adora range. Can't find manual. How do I light??
  • 725 Answers
You need to be very careful with gas, and you may not be able to light this pilot again. Try to use a long lighter to see if it will accept the flame. If it does not, you will need to replace th gas valve. Give us a call and we'll be sure to get the correct part out to you right away! We hope this helps!
Posted on Oct 01, 2009
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
I am looking for a manual to clean my GE Adora self cleaning gas range. grannyof5@bresnan.net
you can try the g.e. web site and click on user manuals,or try www..manualsonline.com and download a users manual for free
Mar 03, 2011 | Ovens
Have a XL44 ge self-cleaning gas range it looks like only one side of burner lights. it takes for ever to reach temp wanted and some times it doesn't get up to the temp wanted. How do I fix this....
Gas valve might need adjusting. themobilian_206.jpgThe spud on top has a nut on it. Turn the nut counter clockwise to make the flame adjustment. You could also need a new sensor themobilian_205.jpg
If the glowbar is weak then that could also be the problem. XL-44 Service Manual
Nov 20, 2010 | Ovens
Lighting device will not stop clicking
I am not sure if you are talking about when the burners are on or off so I will address both
If burner is off:
If it is continuing to click and the stove is turned off, this can happen if you recently cleaned it, the switches can get moisture in them and once they dry out it works fine again. If it is dry and clicking when off then you need to have the switches replaced.
If burners are on and still clicking, it is due most of the time to the ignitor probe or burner caps are not aligned. Rust or spills can also cause this. Clean really good around the burner holes where the spark takes place
May 23, 2010 | Stoves Ovens
GE Model #J TP30B0M1BB Oven The oven stopped heating up on either bake or broil. Light and display are still working
Check to see if 2 of your range burners have failed too.  It would indicate that your breaker needs to be turned off and then back on to get 240 V again.  The panel and 2 burners will work on 120 V just fine.
Nov 10, 2009 | Ovens
Tru temp range requires a match to start burner. one of the 4 burners lights the others just click and do not.
There is probably a blockage in the ignition passage or in the burner assembly. Clean everything thoroughly.
Oct 12, 2009 | GE JGRP17 Gas Single Oven
Front right burner on GE glass top range not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Garland gas range
look at the bottom panel below the doors.on the left and right side youll see screws--remove them.open the doors and you should see 2 more screws.pull the panel out towards you.youll see the serial/model number on it or the frame of the oven.if the glow coil is red try to manually light the burner witha paper towel.if the burner lights, the burner may be obstructed --if not the gas valve may not be opening.you will need a voltage meter to test the coil on the gas valve.if you get the correct voltage on the valve coil which is 24 volts ac and no gas the valve is bad.if you dont have 24 volts the ignition board is bad.let me know.
Jan 20, 2008 | Ovens
My GE Xl44 gas burners will not ignite
If there is no spark at all then the circut is not being completed. The main problem that I had was that there was no ignition even though there WAS a spark and gas. I cleaned out the small pin hole sized inlet on the gas valve with a needle. This allowed the gas to enter the feeder and distribute the gas towards the ignition spark properly.
Also it is very important that the range be level. If there is a pitch to the range the gas may be exiting the distribution cap improperly resulting in improper distribution!
Oct 18, 2007 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
79 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
