Question about Motorola Talkabout T5210 2-Way Radio
How do i stop my radio from making that bloop bloop noise after i key it
  • Motorola Master
  • 1,654 Answers
You are either describing a CALL TONE ( The Call Tone obtains others’ attention before you start talking) or the ROGER BEEP (When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.)
To shut off the roger beep, hold in the plus + button while turning the radio on.
The CALL TONE may or may not be a feature of your T5210 radio. I am unable to open the online manual for it to tell for certain. If it does have a CALL TONE feature you would access it by pressing the MENU button until you see a "CA" on the screen along with a number. Using the plus or minus button change the setting to zero, followed by pressing the menu button or the PTT button. The zero setting is equivalent to OFF.
To
Posted on Oct 02, 2009
Why are my speakers of my Monsoon radio making noise when ignition key is off?
Depending on the year of the car. The factory amp may be wearing out and need to be replaced.
Aug 05, 2014 | Pontiac G6 Cars & Trucks
When turning the key of my 08 vauxhall zafira a buzzing comes from the cd player, the disc wont stay in or play yet after after 10-15 seconds it stops..radio plays fine also
The buzzing noise is static from the engine, if it does not make the noise when the key is on but engine not running. If so make sure you have a good ground. Most of the time I have found that to be the problem.
Oct 24, 2013 | Vehicle Parts & Accessories
Stop the sound of a Tone when Keying to Transmit..
That generally means that it's set to transmit on an invalid frequency.
Jul 26, 2013 | Motorola TalkAbout T5530 2-Way Radio
Cb is fine when vehicle is off , but when vehicle is running it feeds motor noise back threw my cb?
There are several things you can do to help limit motor noise interference but first you have to figure out if the noise is coming from the power wire, or the antenna system. Here is how to do that.
  1. Start the car, and turn on the radio.
  2. Trun the squelch off so that you can hear the interference.
  3. Unscrew the antenna coax from the back of the radio.(make sure that you do not key the radio at this point. It is bad to key a radio without an antenna hooked up.)
If the noise goes away when you unplug the coax, the noise is getting in from the antenna system. It's either getting in from bad coax, poorly grounded antenna, or position of antenna. For instance, if its mounted on the back of the truck some times it picks up the fuel pump noise.
If the noise is still there then it is coming in via the power cable. If this is the case then there are a few things you can do.
First. Make sure the radio has a good ground. Next, run the power wire right to the battery. This eliminates most noise. Twisting the power cord helps cancel out some noise. And a knot right at the plug end of the cord also helps. Lastly, if the noise is still bad you can get a power wire ground loop noise canceling unit. This stops most noise.
Sep 08, 2010 | Midland 1001Z 40-Channels Base CB Radio
My galaxy dx 88 hl makes a laoud noise when you key up and the frequency counter it's off. Channel 19 is on channel 18.
my galaxy 88 cb makes a popping noise through the speaker when I key up how do I solve this problem?
Jul 15, 2010 | Galaxy Radios DX- 88HL Base CB Radio
GETTING INTERFERANCE FROM TRUCK,SQUELCH IS TURNED 3/4 ROUND TO STOP NOISE .HAVE TRIED CHANGING BOX,ARIEL,CABLE AND MOUNT,ALSO TRIED TAKING POWER STRAIGHT FROM BATTERIES, NOT SURE WHAT ELSE TO TRY?
Try this. While with the engine running and radio on, while you hear the noise, disconnect the antenna wire from the radio. (DO NOT KEY IT).
If the noise is gone, then the noise is coming in from the antenna. A new location may be needed.
If the noise is still there then its coming in from the power line. You need to get a ground loop isolator. Make sure its not one for RCA cables. You need one for the power line. It connects to your power source, and then your radio connects to it. this will take most of the noise out.
Oct 23, 2009 | Midland 1001Z 40-Channels Base CB Radio
Motorola Talkabout T5210 2-Way Radio Logo
210 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
