Question about Lanzar HTG244 Car Audio Amplifier
My radio stopped working after hooking up the amplifier
I have a crown victoria 1999 p71 and i just put in a new radio and an amp and subwoofers. before i hooked up the amp the new radio was working. after i hooked it up my radio wont turn all the way on, the light will come on but its very low and no display on the screen. when a put the factory radio back in it wont come on at all. all the fuses seem to be fine. whats wrong!
  • 3 Answers
Did you double check your work? Did you check the resistance of the fuses? Just because the fuse appears to be good, it can still be blown. Do you have access to a multimeter? You need to check and see if the head unit is receiving 12 Volts continuous which you put the multimeter probes to the black wire and the yellow wire. Then connect the probes to the black wire and the red wire. This wire should only have power when the car is cut on. If you are not getting 12 volts to these points, the problem is your wiring system somewhere...probably a fuse. If you are getting 12 volts, your head unit is garbage. I want to say it is the fuse.
Posted on Oct 02, 2009
2003 crown victoria p71 ex police car
I would take it out right away, you don't want to be charged for impersonating a police officer. There is no reason to keep it and if you do you will have to answer why every time you turn around and get stopped.
Apr 26, 2017 | Cars & Trucks
Where is the radio fuse in a 2003 crown Victoria
http://www.analogstereo.com/ford_crown_victoria_owners_manual.htm
Aug 02, 2010 | 2003 Ford Crown Victoria
Fuse diagram for 2000 crown victoria
there are 5+ pages of fuses what specifically do you need
Jul 30, 2010 | 2000 Ford Crown Victoria
I have 99 p71 that makes squeaky sound when i dive
ball joints...if it is coming from the front end or could be universal joints
Oct 26, 2009 | 1999 Ford Crown Victoria
Dash lights
have to remove the instrument cluster, careful with the little shift wire, don't break it. best of luck
Aug 07, 2009 | 1999 Ford Crown Victoria
Pulsateing lights
have your alternator check at autozone or advance auto for free!! Sounds like the voltage regulator is bad...hopefully this helps
Jul 24, 2009 | 1999 Ford Crown Victoria
Turn signals stop working , everything else is ok, which fuse is for turn signals on ford crown victoria 2002 p71.
IT IS PROBABLY THE MULTI FUNCTION SWITCH ..THAT IS WHAT YOU USE TO TURN THE BLINKERS ON..TRY TURNING ON YOUR EMRGENCY BLINKER BUTTON AND IF THEY WORK THAT WAY IT IS NOT THE FUSE...THE MULTI FUNCTION SWITCHES ARE PRONE TO FAILURE...
Jul 09, 2009 | 2002 Ford Crown Victoria
Lanzar HTG244 Car Audio Amplifier Logo
227 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
