Question about Dell Inspiron 6400 Notebook
Physical network adapter not installed? The laptop was dropped )-: and now the wireless internet does not work (the Land does (-:) It say the wirless phical adapter is not installed. I reloaded all the intel pro network adapter drivers - but still get the message. I do not see the intel network card in the system/ hardware /device manager/network adapter - whats going on???
  • eamonn_keane Oct 07, 2009
    Hi Spoem, Thanks for that. I opened up the back and there is a small card in white anti static bag held in by a screw. I took it out and then replaced it firmly, putting back the screw. I restarted, but still get the message on starting that a wireless physical adapter is not present. I looked in the system hardware devices list and there is no entry for an intel wireless card. I figure either the card is damaged or itcan not be seen for some other reason -- drivers???
  • 202 Answers
It may have come loose in the slot. On most Dell laptops, the wireless car is located on the bottom of the laptop. There will be a small square cover secured by one screw. Remove the screw and plate to see the card. There will be two wires connected to the card. These are the antennas. There will also be two retaining clips, one on each side. Release the clips and the card will pop up on one end. The opposite end will be in the slot. Pull it out and then re-seat it firmly in the slot. Replace the cover and secure it with the screw. Turn on the laptop and see if the card is identified.
Good luck, and please let me know how this works out for you.
~ Spoem
Posted on Oct 01, 2009
I m unable to use my wirless internet.my belkin802.11gadapter is not connecting for internet
First thing to do is to re-configure the wireless router that you have. Change the name and wireless password. After that, re-install the Wireless adapter on your desktop. Make sure that you will clean all the files installed on your system. Then test if other wireless device can connect to it.
Jun 04, 2011 | Belkin 802.11g Wireless Desktop Network...
I can no longer connect to the internet. I receive the following message: There is no wireless physical adapter installed. My Gateway laptop has an Intel (R) PRO/Wireless 3945ABG Network Connection is...
Try re-installing the wireless adapter.
You can download the drivers for your model Gateway laptopfrom this WEB site. Make sure you select your model laptop and the correctWindows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Apr 20, 2011 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
Toshiba satellite wont connect to internet. Wireless network adapter showing vista error code 31. Any ideas
Try removing the wireless adapter in the device manager and then re-boot computer. Vista should detect the adapter and re-install the drivers. if that does not work you might want to download the latest drivers and software from Toshiba and install them. Another thing you can try is to use windows restore to return the computer to a time when the wirless adapter was working.
Sep 24, 2009 | Computers & Internet
Fujitsu siemens not seeing wireless networks
Go Fujitsu Website and support, download drivers and download the correct WIRELESS NETWORK DRIVER and/or ADAPTER drives. Select RUN and reinstall them (all).
If that does not work then it may be the network adapter which may be behind a back flap. Remove and Replace with same part. Actually its easier just to buy a USB or PCMCIA Network Adapter from Radio Shack to plug in to your Notebook, comes with software and driver installation disk about $40. This is generally the best solution as it works independantly as a "plug in", easier to install if notebook's built in Network Adapter is defective.
Sep 03, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
I have just installed the driver for an Intellinet wireless G usb adapter from the disk it came with. In the instal guid it says once ive installed the driver and plug in the adapter, it should...
did you plug in the adapter before you installed the driver . best thing to do is uninstall and reinstall. as well as that ralink wireless lan card is not what you bought it should say intellinet when installed properly. reinstall thats my advice
Aug 31, 2009 | Intellinet Active Networking Intellinet...
Internet explorer won't open
when it says connected it means to the router, open up internet explorer>tools>internet options>connections tab and tick never dial a connection, or if it's already greyed out it's ok.
Assuming you have run the wireless network connection wizard first to set up the connection, if not it's in network connections and select new wireless connection or set up a wireless network.
Sep 24, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Dell Inspiron 6400 Notebook Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
