My mitsubishi wd-62526 will turn on with sound but no picture. can't even get into the menu. stays on for a minute shuts off and the lamp indicator light comes on.
    Scholar:
  • 39 Answers
Hi
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours and that you TV is 4 years old more likely you are looking to replace you lamp;The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp.
You can check DM;
If you can hear your TV fan working is NOT you power supply,but if you hear a constant clicking you ballast needs to be replace,
A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light.
You can find your parts at:http://www.discount-merchant.com/SearchResults.asp?Search=HD50LPW175?Click=52978
I hope this will help,please keep us posted.
Posted on Oct 01, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
How do you know if your lamp is out. there is still light on in the back of the tv
An LED indicator on the front panel of your TV will blink even you have light in the back panel of your TV this LED indicator will remind you if the lamp must be replace because DLP projection has a lamp hour meter the lamp time for this DLP 6000 to 8000 hours.
Sep 23, 2011 | Mitsubishi WD-62526 Projection TV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
this indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
May 26, 2010 | Mitsubishi WD-62526 Projection TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
Lamp lite
Does the lamp indicator stay yellow, or does it turn red?
May 17, 2008 | Mitsubishi WD-52531 Television
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
