Question about Maytag MED5600TQ Electric Dryer
Dryer will not start
My maytag dryer will not start i have a mod= med5600TQ0Ser # MU1512284 any ideas ?
  • Maytag Master
  • 7,482 Answers
Check your electric going to the dryer to make sure you have power to the machine.
Then check to make sure you motor is not running, sometimes with a broken belt the motor is almost silent when running.
If the motor is not running then your problem may be the start switch, timer switch, or the motor could be faulty.
One thing you can try is to make sure your power is off to the machine, reach in and turn the drum by hand 1/4-1/2 turn. Turn back on the power and try to push the start switch again. Sometimes motors will get dead zones in them and this will move it out of the dead zone.
I hope this helps
Posted on Oct 01, 2009
Want to see a manuel on my new Maytag Dryer Mod: MEDC200XW3
The Maytag should have come with a manual. If not, you can go to the Maytag.com website or Google for it to find the manual for it.
Jul 20, 2014 | Maytag MEDC200XW Centennial Electric Dryer...
New Maytag Electric shock
I believe you dryer is not hooked up correctly electrically.
You will need to unplug it from the wall without touching it.
You may need to use a wooden broom handle or some other insulating items to accomplish this.
Remember, electricity cannot flow through dry rubber, paper, cardboard, or wood.
If you cannot move the dryer away from the plug so you can reach it, you will need to shut off the dryer at the breaker box or fuse box before you start to unhook it.
The breaker box or fuse box should be marked on the paper on the back of the door as to which 2 circuit breakers or fuses are for the dryer, but most are not.
You should get someone smart to fix this before you have a fire or someone killed .
Be blessed.
Jun 14, 2013 | Maytag Dryers
Admiril Electric dryer Mod. # ADE7005AYW. For the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Maytag Dryers
Maytag dryer Mod. MDE5500AZW works but no heat.
do you have 220v going to the dryer? the dryer will still turn and the light will come on if you only have 119v you must have 220v to get heat how long is the vent hose? too much vent hose can cause the heat to back-up causing therostats to blow stopping heat from working
supply more detail???
Jul 20, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Dryer won't start. Mod.# MDE3000AYW . The on button makes the right noise like it is going to start but nothing happens. Sometimes I get lucky and it will start but most of the time it just...
heatman101
Jul 05, 2011 | Dryers
Maytag dryer mod.# medc400vw0 dont start
heatman101
Jul 02, 2011 | Dryers
My Maytag Mod. DE7500 elec. dryer is no longer heating up. Starts and goes around fine just no heat
On this dryer the element is what fails, the screws are on the lower front that hold front on. You will need an ohm meter to verify unless you pull the element out and visually inspect it.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Maytag Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Maytag electric dryer mod#DE612 series02
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
Nov 24, 2008 | Maytag HYG2460AWW Gas Dryer
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Maytag MED5600TQ Electric Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
