Question about Combi Centre DX - Mango
My worcester 28si series 2 boiler will not ignite
My worcester 28si series 2 combi boiler will not ignite when it attempts to the warning light flashes rapidly. any help would be greatly apriciated. Ian
2 Suggested Answers
SOURCE: worcester combi 28si II
new boiler?
Posted on May 07, 2008
I have worcester combi boiler 24CDI RSF, the boiler will not ignite, for the hot water or the central heating, it was working ok, and the red water light is flashing
i think the fan may be stuck. you will need to gain access to the internals of the boiler so a gas safe engineer will need to be employed to do it. if it is the fan, a simple squirt of lubricant will free it and give you anything from a week to a year of trouble free operation but! you will need to get a new fan. Fit a new one as soon as you can as they tend to go at the worst possible time if you dont
Oct 20, 2011 | Combi Centre DX - Mango
MY WORCESTER COMBI BOILER 24i JUNIOR SUDDENLY STOP WORKING. THE WARNING LIGHT IS FLASHING. THE BOILER IS ABOUT 5 YEARS OLD.
when i open the tap for hotwater i can see only the flashing light on and not hotwater at all the guy changed the fan but after changing its no use waste of money i still have this problem i dont want to spend more on it can some one let me knolw the problem so that i can fix ir my self .
Jan 18, 2011 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
Oct 14, 2009 | Water Heaters
Need to repressurise my worcester 28si combi boiler
most worcesters have n internal filling loop, depending on which one you have i.e CDi (left hand side, or Greenstar/ junior (high efficiency) right hand side, there ill be a void, the filling loops are black plastic with either a small grey or white knob, position your filling key pointing up, with the little noggins poiting at 3 and 9 o'clock, so it looks like your putting the key in on the wont almost. Push it up, and twist. (older worcester turn it 45 degress), newer worcester turn to the right slightly, you'll know if its in right because you cant turn it any further on the newer ones. turn the small knob anti-clockwise to let water in, unitl the reuired pressure is reached. Normally 1- 1.5bar is adequate. If you key isnt in right water will come out where the key is. So if it does it means the key isnt in right, dont panic, turn the knob off and try again. Once done, twist key back to its original position and pull out, youll probably gets a few drip out, this is normal.
Unforuntely not the most user friendly of devices if you dont know what your doing.
Good luck
Dec 25, 2008 | Combi Centre DX - Mango
Faulty Worcester boiler
we have a worcester24i rsf boiler installed in our mobile home buy the the water temperature seems locked in at a certain temperatutr any idea how we can change this
Oct 19, 2008 | Combi Centre DX - Mango
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Combi Centre DX - Mango Logo
520 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
