Question about JVC Cybercam GR-DVL520 Mini DV Digital Camcorder
Tape won't go in
I have tried switching tapes but it won't shut.
  • 4,402 Answers
Try tapping it on the side
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
-I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Dec 20, 2007
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
Tape deck on Panasonic RX-DT680 boombox issue
I think this should be a simple fix! The deck will have switches at the top of the cassette compartment. These detect the tape and also select it for type - metal or chrome etc. These switches have become bent or damaged or have dirt on them.
May 18, 2013 | Audio Players & Recorders
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
Drivers-side rear door won't engage-interior bell chimes constantly
Make sure the rear cargo lid is shut. Then if it still appears to be the door, then remove the jam switch in the door sill. The switches usually separate the wires when the door closes. You do not want to lose the wiring inside the doorjam and you do not want to leave a hole open either.
Tie a string on the wiring and/or tape the wiring to the doorjam until you can get a new switch. Tape the wire ends to prevet shorting.
Feb 04, 2012 | 2008 Chevrolet Uplander
The machine won't erase my tapes? Is there a chance it could be a faulty machine?
Does the erase light come on and the tape rewinds? Or does it just beep when you try? Could be a bad erase switch, sometimes pressing harder will do the trick. If it just beeps, try another tape.
Jul 18, 2011 | Sanyo TRC-7060 Desktop Cassette...
I have a tape which I'm anxious to play to convert to a CD, but it just won't play ! It will fast wind both ways but on play just shuts off. (It hasn't been played for a long time) It does...
If you wind the tape by hand (with a pencil or screw driver etc.)is the tape easy to turn or move from one end to the other with out any binds? If not It may be wound unevenly, smacking it down on a flat surface a few times on each side will usually free it up. Hope this helps.
May 17, 2011 | Audio Players & Recorders
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
F08 Error message, keeps shutting down
Get it to a shop. The error is a drum servo related problem. Don't force the mechanism or you'll be out even more...accordianman
Feb 15, 2008 | Panasonic AG-DV2700 Mini DV VCR
JVC Cybercam GR-DVL520 Mini DV Digital Camcorder Logo
107 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
