Question about Blue Mio Moov 330 GPS for Europe 4.3" screen Touch , tooth Car GPS Receiver
My device is stuck on the usb connection display.
Hello! My device is stuck on the usb connection with pc display. I reset a dozen times and nothing.I updated it with the latest map and still nothing.
  • 2 more comments
  • dark_amazzon Oct 01, 2009
    Thank you for replying but...what do you mean exactly? That it can't be fixed??
  • yadayada
    yadayada May 11, 2010
    they cahrge $60 just to look at it, so you decide
  • yadayada
    sorry but the GPS is caput!
This is not tru,to make your gps operational again,contact me :
luca_mzq@yahoo.com
Posted on May 29, 2010
    Top Expert:
  • Blue Master
  • 78,936 Answers
The question is yes of course it can be fixed, the cost of that repair may and most likely will exceed the cost of the GPS. So in most cases the best thing to do is just replace it.
Posted on Oct 01, 2009
Nikon d3100 stuck on flash mode
What do you mean by flash mode?
Have you read the manual how to use the camera?
If nothing from there helps, try connecting it via USB and check if there is firmware update. If even that doesn't help, try acessing menu and doing hard reset from there.
Mar 03, 2014 | Nikon D3100 Digital Camera
Recognition of recorder
Does the computer recognize the Olympus DS-30 being connected to it at all? If not, do you happen to have another USB cable that you could try using? Either way, you should try connecting it to a different USB port on your computer, as you might have happened to connect it to one that doesn't work.
Jan 06, 2008 | Olympus DS-30 Digital Voice Recorder
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
I purchased 2 Coby MP600. I thought I was downloading music the wrong way on one of them, so I did a format. Now when I plug the device in, the device media manager, I get this message" Device is not...
Hello.
I will suggest you to try to connect it to your PC on different USB-port first. If all the USB hub gives you the same message, then try to connect it on another computer/laptop. This is to make sure if the USB-cable is working properly or not.
And if you get the same 'Device is not plugged currently' message when trying it on different USB hub and different PC, you'll have to update your MP3's driver.
Feb 24, 2010 | Coby Audio Players & Recorders
Tom Tom Go 520 can not connect to PC.
I had the same problem with a 750.
I cured it (accidentally I must add) by inserting a memory card.
I guess the last time I connected and disconnected the 750 it had a memory card in and without one inserted it would not recognise the device.
Strange reason but worked for me.
Jan 10, 2010 | Tomtom GO 700 GPS Receiver
When plugging in our coby mp822-4g mp3 player the welcome screen appears and says Please Wait. But it never goes past this. It seems to be frozen. Even after unplugging it nothing changes.
When using the MP822 for the first time it should be charged for 8 hours before using.
When the player is coming up with the welcome screen while connecting to a computer, switch the player off while connected.
Connect directly to a running computer, charging the device (in the power off status) for a longer period. The USB symbol should be displayed on the player's screen.
When not being able to get the player in the off status, reset the device:
1. Disconnect your player if it is connected to a computer.
2. Use a paper clip to gently press the Reset button located on the bottom of the player.
When this was helpful I'd appreciate your vote.
When needing more information, just add a comment.
Jan 01, 2010 | New Motion Audio Players & Recorders
My PC can't seem to recognise my Creative Zen Vision M 30gb anymore. It has been working fine but today nothing doing. The display on the device says it is docking when I plug into PC but PC says it is not...
What you have to reset is the PC, not the Zen.
Try unplugging the PC AC cord for ten-fifteen minutes. This will drain power and get rid of electrostatic charges accumulating on USB connector contacts.
If that does not work, check USB status in device manager, and test the Zen with a different cable. Also test the unit on a different computer.
Aug 14, 2009 | Creative Labs ZEN Vision:M Digital Media...
Polaroid MPU-43315B Personal Media Player stuck on 'initialize' -
i'm having the same problem. I'ts stuck on "Welcome" and nothing happens when i connect it to a computer
Feb 01, 2009 | Archos 104 MP3 Player
Windows Will not detect my Philips SA6045 4gb mps player
Whenever i cannect it ,nothing comes up,nothing in "my computer" to click on.I update the driver for it,it works for about 20 seconds,then the device becomes unresponsive and i have tp update it again,which again it will connect for a short time ,become unresponsive,and then the update process.How do I keep my MP3 Player Connected.Also nothing is wrong with my USB chord.
Sep 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Linksys WUSB300N, cannot install driver
are you followin THESE instructions?
have you uninstalled the software that came with card?
With the card installed, go to device manager and expand the Universal Serial Bus Controllers tree and see if there are any ? or ! devices listed there
Also check under the network adaptors tree for same thing.
If there are any devices with either ! or ? highlight them and in the menu across the top select "action" and uninstall.
Do you hear the "ding" that usually occurs whemn a USB device is plugged in? if not this may indicate a connection issue
Try all USB ports on PC. Perhaps there is either a bad USB port or the connection is not good. Try connecting card via a USB extention cable (male to female) as it is possible that the shape of the card or the PC case means that the USB is not incerting far enough for good connection.
please post back results so I may assist further if required
Jul 08, 2008 | Linksys WUSB300N Wireless Adapter
Blue Mio Moov 330 GPS for Europe 4.3" screen Touch , tooth Car GPS Receiver Logo
986 people viewed this question
Top Blue GPS Experts
Will Halftowaite
Are you a Blue GPS Expert? Answer questions, earn points and help others
