Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Red pixilation in the black areas of the screen
When the screen has a black picture (whether it is from a movie or a tv show) it had a red pixilation and shadowing that doesnot go away right away.
Mine has the same problem and today after having it for 3 yrs I have sound and no pic..does anyone know who I call to fix this I paid too much for this tv
Posted on Oct 03, 2009
The dark areas of a picture is red
the screen itself is going bad and wearing out . there is no repair except replacement of the tv .
the screens are so expensive to buy there would be no point
sorry i could not bring you better news
Feb 02, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
PS3 pixilation, chopy graphics
You might have to much data on the ps3 try cleaning some stuff off
Oct 02, 2012 | Sony PlayStation 3 Slim Black Console
I own a toshiba 19dv500 and am having trouble viewing a dvd, the system is working but only in black and white, no colour\???
Hello there,
A black and white picture is most often due to a faulty or incorrect RGB (red/green/blue) connection or cable.
If you are using a composite connection (red/white/yellow RCA jacks), you have probably connected the yellow plug to a socket labelled Pr/Pb, Cr/Cb, or Y - on either the DVD player or the TV - most probably the TV. The yellow needs to be connected to a socket labelled "VIDEO". If you connect this to any socket labelled Pr/Pb, Cr/Cb, or Y, you will get a black and white picture.
If you are using a component connection (red/green/blue RCA jacks), one of the plugs is either not fully inserted into the socket or is in the wrong socket. If you remove any one of the R/G/B plugs, you will get a black and white picture.
If you are using a SCART cable (UK / AUS), you may have a bent, damaged or disconnected pin.
I suggest you check and correct the connections between your DVD player and TV. If you are unable to locate the problem, please try another cable as the one you are using may be damaged. If you are still unable to locate the fault, please let me know the brand and model number of the DVD player and how it is connected to the TV. If required, I can also draw a diagram showing the correct connections.
It would also be useful to know whether this "fault" suddenly occured, or whether you have just connected the player to the TV.
Hope this helps - please let me know if you need further assistance.
Regards,
BElectric
Mar 03, 2011 | Toshiba Televison & Video
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Black showing as red on LCD
this is a LVDS cable issue. All you have to do is call Vizio and they will send out a tech and replace the LVDS cable along with the Main Board. This should resolve the pixilation issue.
Feb 21, 2009 | Vizio VO47L 47 in. LCD TV
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Samsung plasma tv 42inch PS42E THDX Blue sparkles on dark areas
Hi yes i had the same problem and its basically because the tv needs a software upgrade. I contacted argos and they sent an engineer to sort it and he plugged something into the back of the tv to upgrade it. all in all it took 5 mins to do and not had a problem since.
Jan 31, 2009 | RCA PHD42600 42 in. Plasma Television
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
314 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
