Question about Bell Sports Doubel Back 2 Bike Rack
Best way to install on a hatchback,
When installing the rack on a small hatchback (VW golf), where does the swiveling U-bar go? Is it loose on top or does it have a purpose?
  • 85 Answers
The top bar can rest against your back window, the U bar that swivels can go ontop of your bumper, no bumper? then try to attach it so its help by a lot of pressure on the straps!
Posted on Oct 03, 2009
1997 VW Golf - leaking radiator fluid from water pump
Yup, That's the weeper valve. The water pumps are designed to start dripping before completely failing. Sounds like it is time for a new water pump, timing belt and all. When you replace the water pump, don't let the stealership bully you into a stock pump. The plastic impellers like to break off. Get a shop to install a new pump with metal impellers.
Aug 09, 2013 | 1A Auto Parts 1997 VW Golf Hatchback Rear...
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
Dec 21, 2010 | Volkswagen Golf Cars & Trucks
I am gettin a knocking noise on small pot holes i think its the anti roll bar bushesits a vw golf 2004 mk5
Its more likely to be the bushings on the top of the shock towers. they are favorite for this
Jul 19, 2010 | 2005 Peugeot 405
Uninstall Sharper Image Tie Rack from clothing rod
The tie rack just clips on in the middle. the small piece on the top of the bar in the middle of the rack slides to the left to uninstall, to the right to install. on the bottom middle of the rack is a round piece that tightens to hold the rack level. loosen that piece first, that the top middle piece should slide to the left.
Dec 30, 2009 | Kitchen Appliances - Others
2003 Protege5 front suspension knocking noise
Upper strut mounts aren't prone to rattling or knocking as they are usually under load all the time. Very few cars do not have a swivel bearing - a few old Fords are all I can think of. Most current models have the swivel bearing integrated into the strut mount, the main job of which is to insulate road noise from the body. Some cars use a swivel bearing fitted between the strut and lower spring cup.
Worn shock absorber internal valves can be very noisy over small bumps and road undulations and wear in steering rack components can make similar noises especially the rack slipper bearing, the rack end support bearing and the rack end joints.
Many track control arm ball joints have an internal spring to compensate for small amounts of wear. When such a joint has worn significantly it is not always possible to detect free play with hand pressure but they are liable to make noise on the road.
Struts that are housings fitted with shock absorber cartridges retained by a single large nut - the nut can sometimes be loose by a small amount causing the cartridge to knock inside the casing.
The strut piston rod and bush is subject to a great deal of force from the reaction of acceleration and braking and considerable wear can take place between the rod and it's bush. The trouble is any free play cannot be detected when the vehicle is jacked and the wheels clear of the ground and similarly cannot be detected with normal force when the vehicle weight is on the ground. I find lifting the car until the suspension is only compressed an inch or two gives the best chance of detecting wear though considerable strength and energy is still needed.
Mar 10, 2017 | 2003 Mazda Protege
Install an ac in a 1997 vw golf
buy another car,to fit A/C now is more than the car is worth,install a sun roof instead
May 09, 2009 | 1997 Volkswagen Golf
Looking for an Owner's Manual (in English) for a right hand drive model.
In my Judgement the best place to get your owners manual for this car would be your Australian VW dealer or on www.ebay.com
Apr 29, 2009 | Volkswagen Golf Cars & Trucks
Golf user manual
you can call your local vw dealer and get the factory manual for $50.00
Jan 10, 2009 | 2000 Volkswagen Golf
Bell Sports Doubel Back 2 Bike Rack Logo
457 people viewed this question
Top Bell Sport & Outdoor - Others Experts
Are you a Bell Sport and Outdoor - Other Expert? Answer questions, earn points and help others
