Question about RCA OPAL M4001 MP3 Player
Disk is filled, won't format
There are no songs on my mp3 player,when I try to put something on it says the disk is filled. i tried formatting, but it says it is unable to format. I just bought it and have never used it yet.
  • 8,596 Answers
Delete an individual songs or two first, and then try reformatting.
Posted on Jun 18, 2008
Whenever the player is tried to open, automatically it gets switched off and I am not able to operate the same and hear songs
I think you might have formatted the Mp3 player using wrong format...
connect the player to the computer using an usb cable. It will open as a removable disk. Just make a right click on the removable disk and select "FORMAT"
Select the file system as FAT32 and format it using the default allocation size... Now load songs to your player, it should work....
May 19, 2011 | Transcend T.sonic 610 MP3 Player
When i went to put some more songs on it it wiped everything and now "says no files" when i try to put a song on it wants to re-format disk? but i aint using a disk?
Although your player is equipped with flash memory and not disk, your device will appear on your computer as a drive named as "removable disk". You can re-format this:
Use windows explorer and right click on this drive and choose from the pull down menu the "format" option. The type of format should be FAT or FAT32.
Then your player will be empty, no media files will exist and you can use your device again.
Take care certain type of players must not be formatted using windows but only with its own software.
You should look for this in its user manual.
May 03, 2011 | Audio Players & Recorders
Tranfering songs problem
Go to My Computer in your start menu and double click while your mp3 player is connected to your PC. You will see your player listed there, right click on it and select format, you can select quick format. This will get rid of any large files taking up space. Now start adding music again. Also, when ripping music to your computer, your want to make sure you rip as Mp3, not wave, as wave files are much larger. Let me know how that works for you.
Nov 17, 2008 | SanDisk Sansa m230 MP3 Player
Transfer files from disk to iriver ifp-895
The songs are probably in the wrong format. convert them all to Mp3 format, and try again.
Aug 26, 2008 | iRiver iFP-895 MP3 Player
My mp3 player has nothing on it but the space is used by something and when i try to put songs on it it say disk space full insert new disk
Reformat the player to make the computer read the player correctly again:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 22, 2008 | Audio Players & Recorders
Ilo mp3 player
The may be a problem with your boot files stored on your MP3 player, try formatting which may fix this problem.
First you go to "Start" - "My Computer" - Now look for something called "Removable Disk" - That is your MP3 Player - Now right-click on it then click "Format" - Now allow format to complete and this should have fixed the problem.
Now you've formatted put some songs on, then unplug then try.
Good luck. Hope my solution was helpful in someway.
Nov 30, 2007 | iLO (2 GB) MP3 Player
My sansa does not recognize most of the songs
This could be a bug, and you may need to update your mp3 player also the drivers.
Below is the link to your mp3 players drivers just choose the options that match your mp3 player and download and trying then.
I would recommened you to format your mp3 player for before installing any drivers or updates.
If you don't how to format follow these steps.
Click on "Start" - "My Computer" - look for something called "Removavle Disk" which should be your mp3 player. Once you've found that right click on it and click "Format". Once format is complete then go to the site and update the drivers.
Then try putting music on and seeing if it's fixed.
Good luck. Hope my solution was helpful.
Oct 24, 2007 | SanDisk Sansa E280 MP3 Player
Manual for infitek mp3/mp4
Problem: Infitek MP4 player is recognized by Vista and Windows XP but when you try to put files on it, error pops up.
Solution: The MP4 needs to be reformatted to FAT32 file system, here is howto do it:
1) Connect USB cable to PC
2) Connect Infitek to cable.
3) An AutoPlay window will pop up on your PC. Select "Open folders to view files using Windows Explorer"
4) On the left of the explorer window the following will be seen "Removable Disk (?:)" (? can be any letter in the alphabet, most likely E-K)
5) Right click on "Removable Disk (?:)" with your mouse and select "Format"
6) "Format Removable Disk (?:)" window will appear, select FAT32 from the FIle system Combo box and select Quick Format from the Format options and click on START
You may need to format the MP4 more than once, it did not work for mr the first time.
7) After you receive a message, Format completed successfully you can drag and drop any files to the "Removable Disk (?:)" which is the MP4 player storage area.
8) Disconnect the cable, turn on the MP4, if at main menu use the >>| key to get to the Music, Click MENU key to get to the first song, click >|| to play song.
I used .WMA files (Windows Media Player) songs. They seemed to work ok
Oct 07, 2007 | Coby MP-610 MP3 Player
Not able to put in songs
I cant help you with trying to fix the format problem but i would recommend puttingall your itune songs onto a disk and then try to fiddle around with it. You wont have to worry as much. Sorry I'm not much of ahelp though.
Aug 21, 2007 | Apple iPod nano
Uploading songs
Hi there!
Have you tried formatting the mp3 player?
If not, try this:
The mp3 player way for formatting:
By formatting on the mp3 player, it has be on either pause or stop button. Play button will not open the Initialize menu.
So go to menu, settings, scroll down to Initialize, and then click format. It should say OK?
click yes.
A quick Format done screen should pop up.
The computer way is much longer but cleaner.
Go to my computer.
Right click the removable disk (or it would say whatever you named it to be)
and click format.
A screen should come up with some info like capacity and File system.
Forget all that and click Start.
It should probably take 2 minutes.
Then try it once more.
Okay, after it's done formatting, go to Sonicstage and click the Transfer button. After a few moments it should recognize the mp3 player and display the memory.
If it says something way below 400MB, then you have a big problem. However, anything higher than 470MB is correct.
Now Sony say 345 songs and they are correct...that only if you use their conversion tool, which is in the transfer bar. You would have to convert all your songs into their ATRAC 3 form, and that usually takes about 1 Hr for at least 200 songs. (yea I know) But that's the only way you can stuff 345 songs into it.
I almost filled it to 350, but it was on 64 KBPs for their ATRAC3. Sound quality was not bad, but it wasn't that great.
Hopefully this helped!
Please contact me if you need any more help!
Nov 04, 2006 | Sony NW-E405 MP3 Player
RCA OPAL M4001 MP3 Player Logo
18 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
