Question about GE DBSR453EBWW Electric Dryer
I have a sqealling sound coming from inside the dryer when it is loaded and i don't know how to get in too see the problem
  • 1,543 Answers
Unplug dryer. Open top by either removing screws at top of front panel, or if none on your model, pushing in on clips at the seem to release top at front, allowing it to swing back. (still attached at back) Now, remove two screws (one on each side) near the top, holding the front panel onto the side panels. Unhook the wires from the door switch and lift the front panel forward and outward to take it off. You do not have to remove the belt. Just pull the drum forward a bit to get the shaft at the back of the drum out of the sleave (it is a tight squeeze at the front of the side panels). Replace the sleave. Check the drum slides on the back side of the front panel too. Reassemble.
Posted on Oct 01, 2009
I have a Kenmore Elite electric dryer. It is only two years old. The dryer is a HE 3. Model 1108787 or 1108789. It was working fine two days ago then after finishing the dryer load it was on....I went to...
This could be one of several things.
1.thermal fuse is blown(with power off(unplugged)check for continuity)
2.Belt is broken (check belt).
3.loose wire somewhere
4.Door switch malfuntion push in on it and and test for continuity.
5.The control board is malfunctioning.Try removing it and observe the back of it for burnt or cracked places.
6.Motor is bad test for power to motor see wiring diagram and tech sheet inside cabinet.
Input full model # here for parts and diagrams. Model # should be located just inside of door.
searspartsdirect.com
Nov 03, 2010 | Dryers
My dryer has power but won't start
It sounds like one of two things. First of all, if you could let me know the make and model of your dryer, I can give you a more direct answer. But in the meantime, it sounds like its either the door switch is bad...and this is mostly on the upper right side of the dryer door - inside, where the door closes. Or, it could be a bad fuse - which is located on the lower back of most dryers. It has one screw holding it. It's about 1 1/2" long, and has two wires going to it. You can remove the wires and check continuity. If there's continuity (a closed circuit), then its fine. If not, then its bad! You can find either of these parts at your local appliance store. The way to check, or replace the front switch is to open up the top of your dryer. Use a straight edged flat screwdriver to pry open the top of the dryer. It just pops up, and then you can see the switch down on the right side where the wires are coming from, and it should be plugged in to the feed wires coming from the back of the dryer. Don't concern yourself with this part yet. Its all self-explanatory when you see it. Let me know if you need further assistance. If so, please send me the make and model also - that way I can guide you directly to the problem. Good Luck, and I hope this works for you. - Jim
May 06, 2010 | Maytag Dryers
We have a frigidaire , Gas dryer. Our clothes come out with a hard, baked on greased colored substance, that you can kind of scrap of. There is a vent in the upper back, part of the blower sytem, that is...
Hi, If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer model # RES7648JQO Serial # MK2707517 I put up a load of clothes to dry and when the cycle is done the clothes are still wet and there is water on the door inside the dryer. I've tried adding a...
it sounds like an airflow problem. check everywhere the air flows. inside the lint catch. the vent behind the dryer may be clogged or kinked. the exhaust line in the floor or wall of the house might be clogged. 689b12c.jpg
Aug 01, 2008 | Roper Dryers
Problem with top dryer on stackable frigidaire
The switch may be bad or just not engaging when the door is closed. To test it you could tape something to the inside of the door right where the door meets the switch and see if it comes on. I did that and it worked. I use it as a temp. fix.
Jun 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
Water comes out bottom when I run multiple loads
pull the dryer and check your venting you can remove the vent and run a load to see if it works ok i know the hot air will come into the room but it is just a test to see if the vent is clogged this is where the condensation would come from chweck that and let me know
Mar 15, 2008 | Whirlpool GEW9250 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
130 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
