Question about Creda Ovens
My creda reflection oven model no 48196 lights behind the control panel have stopped working. The neon lights for the oven temp work but not the ones behind the temp dials.
SOURCE: Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Posted on Jun 28, 2008
  • 1462 Answers
SOURCE: creda reflection double oven and grill
if fan inside oven starts but no heat, then the probability is that the element is open circuit and needs replacing
Posted on Jun 29, 2008
SOURCE: creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Posted on Jan 21, 2009
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
SOURCE: creda reflection cooker
There's a florescent tube which runs along the top inside the front panel. You have to take a fair number of screws out to get to it as I remember!
Posted on Dec 19, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Thermador oven control panel light is not working
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Oven door
hotpoint/creda do a good spares service or try currys masterpart
Nov 12, 2008 | Creda Ovens
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Creda reflection cooker
Dec 31, 2007 | Ovens
Ovens Logo
320 people viewed this question
Top Creda Ovens Experts
Craig Butler
Craig Butler
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Creda Oven Expert? Answer questions, earn points and help others
