Question about Black & Decker 11-3/4" Navigator General Purpose Blade
How do I remove the blade and reinstall a new blade in my Navigator saw. Thanks.
    New Friend:
Before you can mount a new blade onto your black and decker navigator you must make sure the holding pin, (the flat side of the oval part) is paralell to the bottom of the saw. If it is not push the black button that pushes the pin out as hard as you can and with a small wrench move it into the proper position. Mount you blade @ 90 degrees and push it up into position
Posted on Apr 12, 2013
CANNOT LOAD BLADE ROUND PART THAT BLADE GOES OVER IS SHIFTED SIDEWAYS CAINT LINE UP BLADE TO INSTALL
Posted on Sep 12, 2011
  • 2,176 Answers
Go to Dewaltservicenet.com and type in your model number for an owners manual for this saw with instructions that you need. If I have helped you would you please rate this response accordingly. Thank you.
Posted on Oct 01, 2009
How to reinstall saw guard on Mac Allister MAC185LS?
Never heard of this brand of saw. A Google search indicates that MacAllister only makes big earth moving equipment. Otherwise, most saws have an appropriate washer and retaining clip that holds the guard on. And you'll need the original spring to return the guard to the closed position every time you use it. Then there are two shaped washers that fit on the armature that have a 5/8" shoulder to fit a normal saw blade. Finally there is the nut that holds everything on. Hope you didn't lose all these parts. If you did, go to eReplacementparts.com and and enter your make and model. If they don't have what you need you might be plum out of luck. But a new saw.
Oct 03, 2014 | Saws
How replace blade on 7 1/4 circular saw - Milwaukee
UNPLUG THE SAW first!! Look for the blade lock on the top or front of the motor body, Hold the lock button down while turning the blade nut with a wrench. After a bit you'll feel the lock button engage and hold the blade firm. Rotate the the wrench counter clockwise and remove the nut, Slide the blade out from under the guard and replace with a new one. Reinstall the nut following the above procedure.
Sep 15, 2014 | Milwaukee Tool Saws
Trying to find a tool to remove screws from my Navigator saw to replace the blade assembly. Also where can I purchase the blade assembly and the tool to remove the casing .
If you live by any wal mart or hardware stores they should carry the components you are looking for. like sears they will have what you are looking for.
Apr 05, 2011 | Black & Decker Saws
How do i change the blade
Hello. where the blade enters the blade holder there is a screw. Unscrew it, turn counterclockwise, remove the screw and then remove the blade. Reinstall the new one and replace the screw. Joe
May 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
Where do I buy a new blade for my B&D Navigator saw?
I would go to Dewalt.com and typ in your zip code to find a dealer located near you or you can buy it online from them.
Oct 16, 2009 | Black & Decker 11-3/4" Navigator General...
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
How to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
Blade does not turn
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Feb 11, 2009 | Craftsman 10" Table Saw
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Black & Decker 11-3/4" Navigator General Purpose Blade Logo
494 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
