Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Won't wet pick up - Hoover Floormate H3000 Upright Wet/Dry Vacuum
  • 294 Answers
The intake hose may be torn. remove lower tank and tilt machine back. look for the hose in the middle. Check for blockage in the nozzle and the squeegee condition. check filter cover to be in place.
Posted on Oct 11, 2009
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
Do I need to remove my filter from my wet and dry vacuum to **** up water?
The filter is for dry pick-up only. Remove it for wet pick-up.
Aug 26, 2013 | Craftsman 17026 Wet/Dry Vacuum
Shopvac wet/dry isnt sucking up water regularly
Aug 04, 2013 | Craftsman ShopVac High Efficiency...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
What if i use my wet dry vac to pick up water without a filter
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Oct 13, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Hoover floor mate 500
If you mean the footswitch that shifts from wet to dry, trun the machine over with the brush assembly removed. There is a black rectangular oush button on the left side. This is the wet/dry switch. Make sure it is in contact with the white post to the left of it . It is the indicator that moves when you step on it. Push the button all the way in and out until it latches. After that it should work OK. Hope yhis helps.
Kirk Thompson
San Juan, PR
Aug 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have a H3000 Floor Mat The problem is it want pick up the water after the scrub clean the floor. What could be the causeing the problem?
Hoover H3000 Floor Mat
I have a H3000 Floor Mat the problem is it won’t pick up the water after the scrub clean the floor. What could be the causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
91 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
