Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
Alcove hot tub with Hercules Pro Pack control box. I need wiring diagram.
5 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Swanstone Veritek BA-3060 alcove is shorter than the BT-3060 tub
that sounds like the correct dimensions. there needs to be some slack in there so the sealant can be placed around it.
Posted on Feb 24, 2009
  • 659 Answers
SOURCE: installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Posted on Mar 23, 2009
SOURCE: I have a 1988 Jacuzzi brand hot tub and I need a
Ekk, Jacuzzi went bankrupt in 2006. Best of luck to you.
Posted on Sep 05, 2009
mrhotandcold
  • 248 Answers
SOURCE: Need an owners manual or a relay wiring diagram
should be able to pick up one online
Posted on Oct 03, 2009
Hercules manual
looking for a hot tub diagram instaling instructions of pump &heater for #216-225-7727 8/93
Jan 06, 2014 | Computers & Internet
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
Wiring diagram for ff32atc control box
If your hot tub has been submersed by water then you are going to need all new controls for it.
NEW control box with a new topside, New motor and whatever else is electrical under the skirt of the tub.
Start your search by getting the brand name and model number off each item.
Rod
US Parts Center
888-521-6183
Mar 19, 2013 | Pool & Spa
It wont run no lites or any thing. has power into control panal.nothing hums buzzes or any thing,want a diagram to figure this out,model number 12-322-322m thank you this is a seven sea hot tub
The wiring diagram for most control boxes made today are located on the inside panel of the control box.
If this doesn't blow the circuit breaker when you turn the GFCI on then you most likely have a bad circuit board.
US Parts Center
Aug 17, 2011 | Home
I need a schematic diagram on the controler of the H136 Hot tub . The wires to the temperature abd Hi/Limit sensor have been cut (chewed) I need a schematic to determine the sensor location and the control...
If you go to Google and type in H136 hot tub wiring diagram it should provide multiple diagrams as well as Youtube videos on how to wire a hot tub.
Jan 29, 2018 | Garden
Hot tub display says flo2 and doesn't respond
that is a display error showing there is not enough water flow to activate the heater. Take the filter out of your tub and see if the error goes away. if it does then you need a clean filter. if it does not go away then you have probably have a bad pressure switch.
Oct 05, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Need wiring schmatics for my hot tub air switch
Look on back of your spa pack. Thats the big box, uscrew and look on back.
Sep 15, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jan 01, 2009 | Swanstone BT-3060R Veritek Bathtub with...
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
694 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
