Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Turns on with sound. But no picture willnot even go to menu. then just cuts off. lamp light comes on
  • 336 Answers
Hi,it sounds like the lamp .Is it around 2-4 yrs old? Do you hear clicking or like wanting to turn on? If you do it could be the board that powers the lamp.http://www.discount-merchant.com/SearchResults.asp?Search=915P020010+ here's instructions to replace lamp http://guides.fixyourdlp.com/mitsubishi/915p020010.php Good luck and God bless you!
Posted on Oct 01, 2009
No picture have sound timer light blinks .when you turn TV on lamp light come on. Goes off. Tv have sound for 10 min TV cut off type 62" Mitsubishi dlp
How old is your TV set ? if you have not replaced the lamp in 2-3 years that is most likely the problem and need to replace that part.
This lamps now run from $40.00 - $90.00 depending on quality.
Jul 30, 2013 | Televison & Video
Hi MY TV HAS NO PICTURE OR SOUND, AND IT WAS FLASHING RED WHEN TURNED ON, BUT NOW IT WILLNOT EVEN GO ON AND I COULD NOT HEAR THE FANS ON EITHER, PLEASE HELP
Follow the money or this case the voltage--follow power cord into the set and to the power supply board--there will be a fuse there---extremely unusual for there not to be blinking lights if the set does not turn on---
May 28, 2012 | Sony KDS-60A2000 60" HDTV
HL-S5687W looses picture and sound after heating up. When I change the channel, the picture returns. The fan is not coming on.
This does not but does in one way make some sense(I had to read your question a few times).
The key here is the fan does not turn on-----If any of the fans (lamp or others to a lesser degree do not come on: The lamp fan must come on or in a short amount of time--it should turn the set off and some have a lamp light and a temp light----
The set monitors the temperature of the lamp especially when set is turned off---it will not turn the lamp off until it cools to a specific temperature is reached----hence if set on for while and just unplugged which will kill the power to the lamp fan the lamp or even ballast that drives the lamp can be damaged.
Voltage to the fan can be measured and it must come on when set is powered up-----issue could be either fan is bad or no voltage is reaching it===most 2 wire fans will have the voltage marked on them--24vdc equals 24 volts Direct Current etc.
If a fan NEVER COMES ON (especially the large lamp fan) sooner or later something is going to get melted or fry.
Your description is a very good one but the issue is a bit rare (fan dead).
I would if there first check for voltage at the fan when set is turned on---if its there but fan not running the fan is bad.
Seen a few where dirt on the fan or even moving the fan blades made the fan kick on but by then you KNOW it is bad.
Let me know if you have questions or what you find.
May 24, 2012 | Samsung Televison & Video
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The picture comes on for a few seconds and then cuts off and then will periodically come on for a few seconds and then cut off again. Will the lamp cause it to do that, or is it a different problem?
U still have sound throught out the picture cut in and out?Yes,than the two long boards call the LCD inverter boards are dead.Replaced the two long LCD inverter boards will solved this problems.The"LAMP"indication LED light on the screen bazel panel,light up or flahes?Yes,the lamp life span is over,require the lamp replacement.
Jun 07, 2010 | Toshiba 56HM66 56" Projection HDTV
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Hitachi ultravision
It could be you need a new lamp again (your might have gotten a defective one) or "temp" is the temperature sensor that is located on top of you lamp, could be bad also. If the lamp gets too hot, the temperature sensor will shut down you lamp so your TV will not catch on fire. If your temperature sensor has gone bad, your lamp will not turn on at all.
Mar 22, 2008 | Televison & Video
No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Jan 17, 2008 | Televison & Video
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
