Question about Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 660 device has no power.
My device has no power and will not power up either through outlet charger, car charger or computer USB charge. Does it have a battery that may need to be replaced?
  • Garmin Master
  • 2,130 Answers
If the unit will not power up with an external power source, it is not a battery problem. I can tell you that even with the battery removed (I've done this many times), if the unit is working normally, it WILL power up even without the battery when connected to an external power source.
Try pressing the reset button underneath the flip-up antenna and hold for several seconds. If that doesn't resolve the problem, then there is a problem on the main board, probably a failed part in the power regulator circuit.
http://www.sharc.net/gps_dead.htm
- Jim
Posted on Oct 02, 2009
    Top Expert:
  • Garmin Master
  • 76,070 Answers
Yes it has a built in battery, the battery is not owner servicable, and that could be your problem, the battery life is around 2 years, u will need to send the unit into Garmin for an exchange GPS, to get more details the exchange program go to www.mygarmin.com, register your GPS and then select support option, u vcan also call them.
Posted on Oct 01, 2009
2 Suggested Answers
SOURCE: Garnin NUVI 680
Needed to change the fuse
Posted on Mar 26, 2009
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
Mar 24, 2010 | Garmin Nuvi 660 GPS Receiver
Cannot recharge using car recharger - no red light showing on charger plug in. Do not seem to have been supplied with a mains adaptor. Help Thanks Paul
Check the fuse in the car charger by unscrewing the tip - the red light should be on whenever it is supplied with power. Otherwise check your vehicle fuse to the 12 volt outlet (or try another device in the outlet).
Nov 04, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Oct 24, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
When I plug my Garmin Nuvi 660 in to recharge the battery, I can't use it while it's being charged. Is that normal. (Seems kinda dumb.)
Which charger are you using? The USB? AC charger? Car charger? It should work fine when using the AC or car charger. Using the USB places it in USB mode for programming.
Sep 16, 2008 | Garmin GPS
Garnin NUVI 680
Aug 08, 2008 | Garmin Nuvi 660 GPS Receiver
Charging with Cell Phone Charger
Well , maybe yes ,maybe not.
I will recommend this for your NUVI 660:
http://www.gpsmart.ca/item733.htm
$25.00 CDN
Dec 20, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
216 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
