Question about Dryers
I can feel heat in the dryer and it makes a buzzing nosie but wont turn when i press start
  • Dryers Master
  • 7,482 Answers
Turn your power off, then reach inside the drum and turn the drum 1/4-1/2 turn. Turn your power back on and try pressing the start switch again.
Sometimes motors get a dead spot in them and this helps to move it from the dead spot.
If that doesn't help then listen again closely, and may be the humming is your motor running...if the motor is running then that would indicate a broken belt might be your problem.
If none of the above is your problem then your problem could be your motor.
I hope this helps
Posted on Oct 01, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore dryer model 86880100: Start button would just buzz when pressed, sometimes actually start the machine, then the machine would run for a few minutes and turn itself off with a burning smell. Now...
Sounds like a over heated motor which starts when the motor is cool but not after it runs and stop. Burning smell comes from the heated windings on the motor coils.
Make sure that the pully is not binding...which i doubt.
Oct 15, 2013 | Dryers
I have a Whirlpool dryer model LEN2000JQ0. The heating element glows red and gets really hot. You can feel the heat and smell the heat I go to turn on the dryer it makes a buzzing sound and the drum will...
I would change the control thermostat. It is mounted next to the skinny white fuse on the filter housing under the dust cover on the back side.
I worked on a dryer like this that had a heat problem and wrote about it HERE
Dec 31, 2012 | Dryers
When I press the start button on my GE DPSR610EG4WT profile dryer it only makes an electrical buzzing sound and will not turn on or start. What causes this?
The buzz is probably coming from the control switch drive motor. If it is not turning the switch, the dryer wont run.
murf427
Aug 02, 2012 | GE DPSR610EGWT Electric Dryer
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Oct 20, 2009 | Whirlpool GEW9250 Electric Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Maytag dyer MDE9206AYW
moter bad
start switch wont ingage
Jun 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
