Question about Black & Decker Leaf Hog Blower Bv4000
The BV4000 works only on low speed. Is there anything I can do to fix this problem?
I disassembled the blower housing (orange). The switch is a momentary closed 2 position rocker (DPST?). Anyway, I sprayed electrical contact cleaner inside the switch as well as electrical lubricant. I also sprayed silicone on the convoluted switch linkage. That took care of the problem.
Posted on Oct 02, 2009
  • 2 more comments
  • philwarner Apr 14, 2012
    Had the same problem and found what i assume is a thermal breaker was open and jumped it,but now I can't re-assemble it so the linkage pushes the switch. Anyone have a photo of how the switch and linkage should go? The parts exploded views are no help except to show that I have all the listed parts, but the rocker that is rotated by the slider is too far from the switch to push it.
    OK, after spending most of the day trying to figure out if I had lost a part that was also not in the parts list, I discovered the missing part was the blower base which has two prongs that push the rocker toward the switch when you put it on.
  • Carol Parker Jul 12, 2013
    I'm having the same problem. I got it apart, installed a fuse holder and a fuse to replace the one that had blown, but now I can't get that Rube Goldberg switch assembly back together again.
    does anyone have reassembly instructions or a photo?
BV4000 stopped working
Check finger switch is good. From the female cord contact to the switch is not letting current. Could be almost anything from a circuit diode, circuit board, u name it!
Oct 16, 2012 | Black & Decker Leaf Hog Blower Bv4000
Windshield Wiper Only Works On High
There is a wiper speed control module or governor behind the instrument cluster. You can check with the dealer on price and what it looks like. It controls everything but high speed.
You should be able to do a circuit test on it to see if it is working. The low speed side of the motor may be bad too.
Aug 23, 2012 | 1994 Ford Ranger Supercab
My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Nov 18, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Need assembly instructions for a black and decker leaf hog bv4000
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90538065,LH4500.pdf
Nov 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
BV4000 is electrically sparking in the upper part of the motor when running, looks like in/near the windings. Motor has slowed too. Seems hot.
The motor/armature is burnt. It will eventually fail completely. Many times too small a supply cord and too long footage length will overheat the motor. Anything over 25' should have a 12 guage power cord.
Nov 22, 2009 | Black & Decker Leaf Hog Blower Bv4000
My BD, DV4000 has lost power and the motor appears
I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
Nov 03, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
I have an elec B&D 12amp blower/vac #BV4000 type 2 that one day would not start up. it very well kept and has never been in any condension or water because it stays in my house that I moniter the...
There are only a few parts to check on this unit. After you have done that,
throw it away and buy you another unit. The cost of parts and labor exceed having the unit fixed.
Sep 24, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Black and Decker leaf hog, worked fine last use.
I posted this solution on another similar thread, but it may pertain here.
Jun 10, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Black & Decker Leaf Hog Blower Bv4000 Logo
468 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
