Lexmark Optra T614 Laser Printer
Problem for Lexmark Optra T614 Laser Printer
Constant paper jams in lexmark t614
By grinehart on Oct 01, 2009
constant paper jams in lexmark t614
Solution #1
posted on Nov 28, 2009
Not Rated)
lasertltech
Rank: Guru  Lexmark Computer Hardware  Expert
Rating: 90%, 21 votes
it would help to have a bit more information on where the paper jams. but ill give this a shot any way. 241 jams clean or replace the pick wheels on the auto compensator. 201 jams no paper present change main motor drive. paper stops 3 inches through the fuser timming issue check the paper size i the paper menu check the fingers on the side of the tray letter is the 2 bottom fingers sticking out. if you have network port print the network page if it is smaller than the page change paper selction pcb located behind the logic pack. if the the line at the bottom of the read out is missing and the box is incomplete the printer is reporting leagal size paper change the paper size pcb. 202 errors check the sensor flags on the fuser. there are 2 sensors on the fuser the one on the left is the narrow media sensor the one on the right is the exit sensor. check to make sure the sensor flag is not broken. check them for fluid movement if you cant hear them snap back replace the sensors hope this helps you out
Was this helpful?
Yes
No
Popular Solutions for Lexmark Optra T614 Laser
Questions and Unsolved Problems for Lexmark Optra T614 Laser
Do you recommend Lexmark Optra T614 Laser Printer?
Answer
Answer
900 Service RIP Softwrae on LexMark Optra T614.
Answer
what is the default password for the Lexmark T614 Optra? Trying to get on the web interface and... (More)
Answer
Paper folds at heater roller Asks to remove cartridge as paper folds up and wont progress to final... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
