Question about Maytag Dryers
Maytag dryer stopped working (model LDE9334ACE - electric). Dryer light DOES NOT work when door is open. Checked circuit breakers and that's fine.
  • Maytag Master
  • 7,482 Answers
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
Posted on Oct 01, 2009
Does the maytag dryer have a reset button. The dryer was working fine then just stopped turning on.
No, they typically don't have a reset button. But they do have safety switches which can fail. Usually there is a microswitch on the door. When the door is open the dryer won't start. Do you have power at all to the dryer? Do any lights light up? If not, you may have tripped your circuit breaker to the dryer and need to reset them. Typically there will be two breaker switches tied together to move as one in your power panel for your house or apartment. If you are not sure the breaker has tripped, it won't hurt anything to switch them off and then back on again. If this does not help, you likely have a failed switch or relay in the dryer that will need to be replaced. Also check that your lint trap does not have a switch which will prevent to dryer from running if you have too much lint in it.
Nov 04, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer stopped running in the middle of drying cycle. Circuit breaker was checked and reset. The light inside dryer will not turn on when door is open.
check that you have power coming to dryer...check for burnt wires going into cord area...it also could have blown your thermal fuse. its best to have a electrical tester to check componants
Jan 14, 2011 | Maytag Dryers
While drying clothes yesterday the dryer stopped halfway through. There was only about 10 or so shirts. When I noticed it had stopped I opened the door and reshut it, but the dryer wouldn't work anymore....
you may have a defective timer, or worse a defective motor. the door switch may also be defective, you require a basic knowledge of motors switches and timers, and require a volt/ ohm meter to diagnose properly
Apr 28, 2010 | Maytag PYE2300AY Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
No power after door is shut
Check all fuses and circuit breakers , test with a multimeter the door switch, ensure it is working, if this parts are fine, then the problem is with the control timer. In that case you will need to replace it.
See also the following website: What is wrong with your Dryer?
You can get replacements here, also insert model number to get schematics.
Sep 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Ensignia Model MDE6657BYW stopped...
yep there is and it is on the right side of the heater housing, it is connected by 2 white wires, you have to remove the heating element toget at it part is a la-1053
Apr 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Dryers Logo
173 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
