Question about Nokia 6300 Cellular Phone
Want to retrieve my mms from my Nookia 6340 - Nokia 6300 Cellular Phone
Retrive mms message
Under normal circumstances, phones that have SMS support also have MMS support. Check with your carrier to see if your plan supports MMS messages. If it does, check with your carrier on how to set up your phone to retrieve MMS messages. If you have MMS support, it doesn't require a data plan or Internet.
Dec 11, 2013 | Nokia Cell Phones
Received mms from 09478835873 but i can't retrieve it
MMS is one of the feature of the mobile service that you have. You are using smart for your mobile service,right?
There are settings on the phone that should be taken cared of for you to have access with other services. MMS is one of them. Once MMS setting is not yet set on your phone,once someone sent you MMS, you will not be able to retrieve it nor open it for your MMS settings were not yet installed,it seems not activated.
You need to call smart for them to send you the settings. Once you recieved the settings via sms,just save it. For you to check if its working for sending and recieving,just send an MMS to your own number.
Thanks for choosing www.fixya.com
Dec 05, 2011 | Cell Phones
I had received mms from http://mms.live.vodafone.in my message key is MSG 52. 0676 how can i open
i had recieved mms msg from http://mms.live.vodafone.in and given message key its not opening how can i open it
Oct 30, 2011 | Cell Phones
How do you retrieve mms pictures on a samsung smartphone
1st acitivate ur partener an u setiings received ur network proviter ok
May 14, 2011 | Samsung Cell Phones
How can i open an mms?
you should have to first retrieve the MMS........
Select 'Menu' Go To 'Messages/Inbox and select MMS and go in 'Options' it will be the option of 'Retrieve' jus select it......and give sum time to MMS.......your MMS will be open..
thnx
Nov 08, 2010 | Nokia N73 Cellular Phone
My LG pop will not let me retrieve mms messages! help please!!!!
The MMS delivery process is triggered by a special SMS message called the "MMS Notification". The "MMS Notification" contains a URL pointer back to the full content of the MMS message. So when the receiving phone gets the MMS Notification, it must connect to the URL in the notification in order to retrieve the actual message content.
The error that you include above looks like the URL cannot be fetched.
If it worked before, but it does not work now ... then it is possible that something has changed with regard to your firewall or network configuration. The receiving device needs to actually connect back to host server in order to retrieve the MMS content.
It is also possible that something has changed in the configuration at your mobile operator. Hope it will be helpful to you.
Apr 05, 2010 | Cell Phones
Help with mms on ks360
if you are using an unlocked device on at&t's network you will not be able to ever send/retrieve the mms messages, the reason for this being that at&t does not support the use of internet on an unlocked phone, and in order to send/retrieve the mms messages you must be able to connect to internet.
Jan 13, 2010 | Cell Phones
I want to retrieve mms http://mmvd.mtn.co.za?pw=085279
I want to retrieve mms http://mmvd.aicent.net/mmv2?pw=924482
Oct 09, 2009 | Nokia 6500 Slide Cellular Phone
Retrieve mms http://mmvd.mtn.co.za?pw=444055
i got a mms and i cant retrieve it. what do i do
Aug 24, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6300 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
