Question about Sony PlayStation Portable (PSP) Console
PSP won't power on
Son's PSP won't power on. I've replaced battery with no luck.
    Problem Solver:
  • 6 Answers
The PSP is bricked...
ok their is a solution to this problem.
the solution is called a pandora battery (google it!)
it pretty much lets you start the psp in a way that you can reinstall all the default settings or you can have a custom psp
wich will let you play vaious emulators on the PSP, you can play PS1 games and you can play backed up psp games with just a memory card.
Posted on Feb 18, 2008
  • 4,402 Answers
When you play a new game for the first time, the psp checks for the firmware version of your psp. If a newer version is available, the disc will require you to update your psp. If you do not update the game cannot be played. If you update, you MUST charge the battery 1st. Then, you must have the charge plugged in and allow the update to run uninterrupted. If you remove the game or unplug the charger during the update the bios chip will be ruined and you now have little more than a "brick".
When this happens, the unit completely locks up and has to be replaced. Basically, it corrupts the operating system and there is no ability to restore default settings as a back-up.
Posted on Dec 20, 2007
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
My psp2006 will power on but the screen will not light, i think it was smashed by my son
you could try removing the battery then charging it without the battery then try to start it cause it worked with my psp hope it will help
Apr 29, 2011 | Sony PlayStation Portable (PSP) Slim...
PSP powers up, black screen, no sound
It could be, although if it hasn't been modified in anyway it could be the battery. If your son has used this battery so many times, say a couple months or years, the motherboard or chip could malfunction, causing shortage of power. Try getting a replaceable battery, or if you know another friend or guy that has a son/daughter with an extra battery try using it to save money. If it's not the battery, could be the firmware, or version. Hope these solutions help, let me know if they do or don't.
Good Luck!
Jan 03, 2010 | Sony PlayStation Portable (PSP) Console
My son sony psp the green light comes on but has nothin on screen then turns itsself off again does this after it was updated
hi your psp is bricked u need to flash it will need a pandoras battery and magic memory go here you will need a modded psp tho or check the site 4 another way if u can get hold of a modded psp good luck
Jul 26, 2009 | Sony PlayStation Portable (PSP) Console
PSP Will not start
What hapenned to all your PSP's is that they 'bricked'. When your PSP is installing an update and you interrupt the process, the data where the PSP's operating system (=firmware) is stored got corrupted (=broken). In very rare cases this can happen when you play a game and something goes wrong due that game. When your PSP is bricked the green lamp is on but the screen stays black.
Now straight to the point..The solutions:
1.If your PSP 'bricked' because you interrupted a system update (Powered off while updating, canceling update..), then you can only help it by re-installing the firmware correctly. NOTE: This is unsupported by Sony and is something you do on your own risk, for a usual PSP user it is a complicated process and i suggest you should let someone with experience do it. If you still want to attempt it, for example here's a tutorial for making a 'pandora battery' :
To find more information about this subject you could seach on google for tags like 'psp pandora mod custom firmware jigkick'
2. If your PSP suddenly doesn't start up after or while you played a game, then you have a chance that you can recover your PSP without too much hassle. Simply let your battery run empty. After it's empty, remove the battery and let your PSP 'rest' a day without battery. After that, reinsert the battery, first fully charge it, and THEN start your PSP up (after your battery is fully recharged). If you have luck you might have your PSP working again.
3. Contact Sony and explain the situation. Explain that you did nothing wrong. If your PSP is still under warranty they should help you..
Good luck and if i helped you please leave feedback! Thanks
Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
PSP console not working
you failed to state if your son was doing the update via UMD disc. im inferring so, so if the battery died while it was updating, your sons PSP is bricked. you need a Pandora battery + magic memory stick. you can find them on ebay, amazon, anywhere. also if you ask around where you live some people may do it locally.
Apr 27, 2008 | Sony PlayStation Portable (PSP) Console
Power light
you need a new power swich ? which you can perches of ebay
Mar 01, 2008 | Sony PlayStation Portable (PSP) Console
Psp turns on but there is a blank screen
it probably froze try and remove battery. if that dont work turn it on and wait a second then hold the power switch in the off position but do not let go until it turns off that should completey restart it.
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
131 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
