Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Hoover Wind tunnel cyclonic is dead. Will not
Hoover Wind tunnel cyclonic is dead. Will not turn on. Unit is about 6 months old.
SOURCE: Hoover Wind Tunnel ON/Off Switch
This happens all the time on our vacuum. Just remove the handle and switch the button manually inside. You will have to do this from time to time as the power switch on the outside will constantly stop working. This, along with the belt replacements are the common complaints on this machine.
Posted on Jul 28, 2008
  • 97 Answers
SOURCE: Hoover wind tunnel cyclonic U5780900
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Posted on Oct 02, 2008
Pnutgllry
  • 57 Answers
SOURCE: Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Posted on Jan 06, 2009
galati2k
  • 281 Answers
SOURCE: Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Posted on Apr 23, 2009
Vac Belts
  • 701 Answers
SOURCE: How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Posted on Nov 03, 2009
Hoover 30600 max wind tunnel less than a year old makes a whistling noise
Ours did too. I bought a Dyson.
Check for gaps in the hoses and in the wind tunnel canister. Something is not sealing properly.
Nov 11, 2016 | Hoover Vacuums
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Can not find a proper fitting v-belt to fit my hoover wind tunnel cyclonic. i even ordered it from hoover.
The correct belt is # 38528034 ( package # 40201200 ) This belt may seem loose when it is installed, because there is an "idler bearing" that pushes down on it when the handle is released and dropped back.
Mar 07, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Hoover wind tunnel cyclonic U5780900 1 year old. brush will not turn. too much slack in vbelt when in carpet position. Belt is good
-R
Oct 01, 2008 | Hoover Vacuums
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
78 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
