Question about Canon PIXMA iP1600 Printer
Printer will not print
I just changed my ink cartridge. When I try to print something, the paper always goes in sideways. Then I'll get a message saying that the printer is out of paper.
  • 4,402 Answers
Input rollers are bad or have paper dust on them, try cleaning them off
Posted on Dec 20, 2007
Ink cartridges move back and forth, paper feeds and half way goes sideways creating a paper jam
check closely where the paper is moving sideways.. there is something obstructing the paper path, piece of paper a staple or something.. look closely
May 03, 2014 | HP Photosmart C3180 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error message that paper jam in paper cradle
Try this:
  • open the lid of the printer (from where you can see the ink cartridges);
  • remove the ink cartridges;
  • use warm water and cotton swabs to clean both the ink cartridges and the print head (where the cartridges sit on) off of any ink residue;
  • place the ink cartridges back into the printer and test if this works by printing something.
If you're still having issues, there may be a mechanical problem; in which case you need to get it repaired by someone.
Oct 18, 2012 | HP Photosmart 8250 InkJet Printer
Hello Cindy Wells, I saw you on and I am having a bit of a problem with my Canon PIXMA MP490. Basically every time I try to print something the printer will start working (i can hear it...
hi there,
it may be that a paper sensor is picking up a small piece of paper in the printer. Has any paper ever torn in the printer? if so there may be some left behind. Carefully inspect the printer to see if there is any small pieces of paper in the printer. You could also try unplugging all cables and taking the outer cover off to inspect closer.
Re the ink cartridges, inkjet printers are notorious for ink drying out in the cartridges and the nozzles blocking with old ink, if the printer is not used at least once a week. It happened to me, i had to get a new printer.
Hope this helps
Jul 22, 2011 | Office Equipment & Supplies
We changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
May 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer repeatedly giving Out of Paper message, pile of gunge under cartridge
I still don't know what is causing the ink cartridge to leak (I'm assuming that is what is happening) but after cleaning up the area around with lint free wipes and cotton buds (and rubber gloves!), the problem has gone away. I presume the mess had been affecting the sensors causing the false paper low condition.
Sep 19, 2008 | HP PSC 2355 All-In-One InkJet Printer
Canon imagePROGRAF W6200
To reset the 'MT CARTRIDGE FULL SOON' error.
Enter Service mode Hold down the paper source and online button at the same time, hit the power button once.Continue to hold down the paper and online buttons until you see the printer name "Canon W6200" on the printers LCD display, then release the two buttons.The printer will initialize & enter service mode.
In service mode, scroll sideways until you see the 'Initialize' menu, scroll down to 'W-ink', and press enter. At this point I did something (scroll sideways and hit enter I think) and it came up with 'New W-ink Cart' Hit Enter to get '=New W-ink Cart' and Online to Accept. I powered down and back up, error all clear.
Jan 08, 2008 | Canon imagePROGRAF W6200 InkJet Printer
Canon PIXMA iP1600 Printer Logo
54 people viewed this question
old marine
old marine
